fordor door hinges 1926
Tinner12
Topic author - Posts: 147
- First Name: Vernon
- Last Name: Enis
- * REQUIRED* Type and Year of Model Ts owned: 1917 and 1924 touring,1926 4 door
- Board Member Since: 2011
I need the top and bottom door hinges. Are they the same for each door just flipped over.These are for the left front that I need, but the right rear door seems to be the same. The hole the pin fits in is 1.2 " od. I have found some that were 5/8 " od that will not fit.
- Attachments
- IMG_0623.jpg (86.04 KiB) Viewed 515 times
- IMG_0621.jpg (26.74 KiB) Viewed 515 times
- IMG_0617.jpg (77.21 KiB) Viewed 515 times
Ed Baudoux
- First Name: Edward
- Last Name: Baudoux
Re: fordor door hinges 1926
Tinner12. Email me at Edbaudoux (at) gmail dot com
I'm having trouble attaching the pictures here.
Grayling Michigan
1927 Fordor
1926 Huckster
1923 TT
1930 Fordor
1930 Tudor
1927 Fordor
1926 Huckster
1923 TT
1930 Fordor
1930 Tudor
