For Sale, replacement capacitors for Model T Ford ignition Coil rebuilding. These are excess to my needs.
Type 418P Orange Drop, Round Profile, Polyester Film-Foil capacitors. Capacitance .47 uF, 400v, dV/dt rating of 700 volts/uS. I have installed over 25,000 of these capacitors over the years with no problems or component failures.
Perfect for coil rebuilding.
Available in minimum quantity of 100 for $2.25 each or all 575 capacitors for $2.00 each. Shipping will be additional. Call Ron with your requirements 231-348-5085 if no answer please leave message, I will return your call.
Capacitors for Model T Ford Ignition Coils?
Peter Natoli
- First Name: Peter
- Last Name: Natoli
- * REQUIRED* Type and Year of Model Ts owned: 1923 Tourer, 1919TT, 1926 Speedster
Re: Capacitors for Model T Ford Ignition Coils?
Hi Ron, Peter Natoli here in Melbourne, Australia . If they are still available I would be interested in 100 of your capacitors . Would you be able to quote total price including cheapest available postage to Melbourne Australia, thanks.
You are a bit of a legend when it comes to coils, I recently read an article you produced on generators dated 12/18/2018. I also enjoy restoring starters and generators . I have a generator on the bench at the moment which I have restored . While it is running well I am unsure if what I have done is correct or may need to altered. Are you available to answer a couple of queries ?
- First Name: Keith
- Last Name: Townsend
Got mine yesterday!
Thanks, Ron!
Keith
Thanks, Ron!
Keith
