FS EARLY SPINDLE ARMS (SOLD)
Mark Chaffin
Topic author - Posts: 4792
- Last Name: Chaffin
Mark Chaffin
Re: FS EARLY SPINDLE ARMS
Reduced price as indicated above.
Unprr
- Last Name: Schmidt
- * REQUIRED* Type and Year of Model Ts owned: 1927 coupe, 1924 Model T pickup
Mark, if these spindles will fit the T - 203-4. Photo attached. If so, I will take them.
George Schmidt
George Schmidt
George, your spindles are for later T's. They have the flats on the back side which allow the inner bearings to be driven off. The spindle arms Mark shows are for front axle assemblies which have the over axle wishbone. If you have the under axle wishbone you need the bent spindle arms.
Unprr
Allen, thank you for the heads up.
Mark Chaffin
Still available. I'm guessing.
Unprr
Mark, per the reply from Allen from down under. They will not fit my car.
Sorry, for the late reply.
George
George
Mark Chaffin
No worries.
Mark Chaffin
Re: FS EARLY SPINDLE ARMS (SOLD)
Going to Kurt. Thank you.
Daisy Mae
- First Name: Kurt
- Last Name: Andersson
Thank you Mark!
