WTB 1913 running board brackets
Karl Von Neumann
Topic author - Posts: 841
- First Name: Karl
- Last Name: VonNeumann
- * REQUIRED* Type and Year of Model Ts owned: 1916 touring 1927 tudor 1926 hotrod 1913 speedster (project) 1926 coupe (project)
- Board Member Since: 2022
Wanted 4 running board brackets as seen in thr judging standards book I'm building my 13 from parts and need these to keep moving forward
Trades welcome also
Trades welcome also
Tbird
- First Name: Mike
- Last Name: Bird
Re: WTB 1913 running board brackets
Karl,
It’s very easy to just add material to a bracket and build it up and shape it. I had 3 brackets for a 12 that were a matched set but was missing one. I looked and looked and eventually just got a bracket that was a 14-15 era and added material to match it to the others.
Karl Von Neumann
- First Name: Karl
Yeah I know but I don't need to fake parts if I don't need to some ones got to have someTbird wrote: ↑Tue Dec 03, 2024 8:30 amKarl,
There are differences at the frame end of the brackets that would be far more difficult to fudge. I know 1912 brackets were different from the later ones, but I don't know when the changes were made. They are actually forged in a different manner, and this is reflected in their appearance.
got10carz
- Last Name: Meixner
Karl, I sent a email several days ago. I have some. Steve
Karl Von Neumann
- First Name: Karl
Move to top still looking
rickd
- First Name: Rick
- Last Name: Duquette
Hey Karl, Steve found you some 13 running board brackets. Read his post.
Steve, I'm almost convinced. A close up photo of the frame ends should clinch it.
Karl Von Neumann
- First Name: Karl
I sent a response to your email Steve asking if the cross support tab was the thicker version that's what I'm looking for they do not look like the thicker ones in the pictures your sent
Don ellis
- First Name: Don
- Last Name: Ellis
I personally cut these off the frame of a mid 13 with a flat rear cross member. They are available.
Karl Von Neumann
- First Name: Karl
Move to top not a single person has found a set that fits what I want the lower tab should be 1/2 in the outer bolt hole should be 7/16 no one has submitted proof of this I don't care if you cut them off a 13 frame I'm looking for these specs specifically
Tim D
- Last Name: Dickson
- * REQUIRED* Type and Year of Model Ts owned: 1912 speedster 1911 Torepdo
I have a few in Beloit i will have to dig them out, and check them
Karl Von Neumann
- First Name: Karl
I'll see you on the 26th for the hcca meet so if you have some let me know
Karl Von Neumann
- First Name: Karl
Still looking ...
