FS rear axle bearing SOLD
Tinner12
First Name: Vernon
Last Name: Enis
* REQUIRED* Type and Year of Model Ts owned: 1917 and 1924 touring,1926 4 door
Board Member Since: 2011
Post by Tinner12 » Mon Jan 26, 2026 1:39 pm
have not measured any of them But they seam solid All for $125 including shipping in USA
gtttrobinson
First Name: Gerald
Last Name: Robinson
* REQUIRED* Type and Year of Model Ts owned: 1913 Model T Touring + 1923 Model T Touring
Re: FS rear axle bearing
Post by gtttrobinson » Tue Jan 27, 2026 1:08 am
These need to be measured on both ends before they can be sold. We all have lots of these around that are out of spec now from wear. I sorted through eight to find four good ones for my car.
Tinner12
First Name: Vernon
Last Name: Enis
Post by Tinner12 » Tue Jan 27, 2026 11:10 am
could some one tell me where to measure the bearings
Post by RajoRacer » Tue Jan 27, 2026 11:13 am
Using a micrometer, measure several of the rollers in several places at each end. One can visually see if any of the rollers has been "compressed", it will most often measure under the .498 - '499 - I have yet to locate a .500 roller !
Tinner12
First Name: Vernon
Last Name: Enis
Post by Tinner12 » Tue Jan 27, 2026 11:31 am
thank you for the info
gtttrobinson
First Name: Gerald
Last Name: Robinson
Post by gtttrobinson » Tue Jan 27, 2026 11:40 am
In some of the model t restoration videos and manuals (Chaffin book) they state anything .495 to .50 is good. I've heard that if one end of the rollers is good and the other is undersized some, folks will rotate them so the loaded side of the bearing has the better side of the rollers.
Tinner12
First Name: Vernon
Last Name: Enis
Post by Tinner12 » Tue Jan 27, 2026 12:14 pm
OK I measured. They vary from .490 to .496. A couple were to. 497 One was .489on one end better on the other end. I will take $ 75 with shipping included if anyone wants them Thank you
Mark Chaffin
Last Name: Chaffin
Post by Mark Chaffin » Tue Jan 27, 2026 12:26 pm
.498 is stock size for original NOS bearings. With new axles and new sleeves, you can use bearings down to .490 and they will be superior to the solid bearings. Of course less wear is better. Tight cages are a must. Others may disagree. To each their own.
Ken Buhler
First Name: Ken
Last Name: Buhler
Board Member Since: 2012
Post by Ken Buhler » Tue Jan 27, 2026 12:47 pm
Some years ago, Les Schubert suggested that if some new axles were made larger, we could use good but smaller bearings and still get a good fit. I don't know if the new machining would be finincially reasonable to justify the option.
Work honestly
Stay true to your word
Get the job done right
First Name: craig
Last Name: leach
Post by Craig Leach » Tue Jan 27, 2026 9:38 pm
Didn’t someone used to make the sleeves
a few thou thicker to compensate for the
Worn bearings?
Tinner12
First Name: Vernon
Last Name: Enis
Re: FS rear axle bearing SOLD
Post by Tinner12 » Tue Jan 27, 2026 10:00 pm
Sold to Brad
