1915 Ribbed Clutch & Low Pedal, $49, shipping included
Adam
First Name: Adam
Last Name: Doleshal
MTFCA Number: 23809
MTFCI Number: 1
Post by Adam » Tue Jan 28, 2020 12:08 pm
This clutch pedal has been bead blasted clean. The ribs are very good. The pedal has some light pitting that will surface out easily. The shaft has some heavier pitting that probably won’t effect its operation, but most engine builders would probably want to replace the shaft. If you want me to install a new, reproduction shaft, add an additional $30. Either way, shipping inside the continental USA is included. Please email if you want it. I may not see a post here or receive a pm. Thanks.
marinelli
First Name: dino
Last Name: marinelli
* REQUIRED* Type and Year of Model Ts owned: 1924touring
MTFCA Number: 57014
Re: 1915 Ribbed Clutch & Low Pedal, $49, shipping included
Post by marinelli » Tue Jan 28, 2020 12:18 pm
I would like to purchase the pedal. tell me how to send you payment please.
thanks
Dino
