1909-early 1914 radiator number plates
Topic author - Posts: 680
- First Name: R.V.
- Last Name: Anderson
New, exact reproduction. Price with blank serial number pad. $40. Stamped with correct style numbers (you specify number): $55. Postage included.
rvmodeltATnetsyncDOTnet
- First Name: Bill
- Last Name: Hoffer
- MTFCA Number: 32571
- MTFCI Number: 24364
Re: 1909-early 1914 radiator number plates
RV, how do you determine the number to use if your plate is missing?
Cheers, Bill
Cheers, Bill
- First Name: R.V.
I find a car with a verifiably original engine that has a similar engine casting date, note its radiator number, and stamp the plate with a number that is a bit higher or lower, depending on where the date falls in relation to the engine number of the car whose plate I'm stamping.
- First Name: Philip
- Last Name: Lawrence
- MTFCA Number: 5591
- MTFCI Number: 25062
- Board Member Since: 2014
R.V. could you post a photo of the plate?
- First Name: R.V.
The dull orange appearance of the brass is from the protective film.
- Last Name: Meixner
- MTFCA Number: 28023
- MTFCI Number: 20471
On my late 11 the engine#, dash #, and radiator# are all within about 2000#.
- First Name: Keith
- Last Name: Townsend
- MTFCA Number: 14778
- MTFCI Number: 16305
My late 1911 s/n 85xxx had radiator number 97152
Keith
Keith
- First Name: R.V.
Thanks for the info guys; that's very helpful. Wouldn't mind hearing about numbers from years too.
- MTFCA Number: 121
- MTFCI Number: 16310
Here is an example for you. My '13 has a radiator number 231500. The engine number is 212526. They must have sold a lot of radiators for that number to get so far ahead of the engine numbers!
- First Name: Craig
- Last Name: Raynor
I my 15 Canadian touring has the original radiator in it this picture shows the stamped numbers and it had engine number C631_ _. I also found these body numbers stamped on body the inside drivers door. Hope you find this helpful.
- First Name: Keith
Other late 1911 cars:
s/n 82933 radiator: 92560
s/n 83913 radiator: 79259
s/n 86142 radiator: 97505
- First Name: Colin
- Last Name: Mavins
The Canadian rads have tags I did not know the Us rads did the same ,learn something new every day.
