FS Z TOOLS
Posted: Wed Jan 29, 2020 12:09 pm
by Mark Chaffin
I have the following Z tools available for purchase. Quantities available are as depicted in each photo. As well as the price. Shipping for a single item is $8.30 USPO Small Flat Rate Priority envelope. If you purchase two or more, the shipping will be $15.05 USPO Medium Flat Rate Priority. Purchase several items at a time and save on shipping. First come first serve. Get them while supplies last. Payment by PayPal (Preferred) or check. PM me or call Mark Chaffin (951) 805-0928
Connecting rod clamp bolt wrench 3-Z-647 / 5-Z-209 $25.00 each
Flywheel cap screw wrench 3-Z-1179 / 5-Z-210 $30.00 each
1/2" L socket wrench 5-Z-155 $25.00 each
Main bearing bolt wrench 5-Z-156 $25.00 each
Main bearing bolt nut wrench 5-Z-156 $25.00 each
Re: FS Z TOOLS
Posted: Wed Jan 29, 2020 12:13 pm
by Mark Chaffin
Front axle spindle bearing cone wrench 3-Z-699 $35.00 each
Universal joint to transmission tail shaft wrench 5-Z-196 $35.00 each
Re: FS Z TOOLS
Posted: Wed Jan 29, 2020 1:06 pm
by Mark Chaffin
3/8" open end wrench 5-Z-195 $20.00
Body bracket connecting holding wrench 5-Z-212 $25.00 each
Carburetor to manifold and generator mounting wrench 5-Z-817 $30.00
Connecting rod cap nut wrench (for removing #4 piston on a 3-dip pan) 5-Z-157 $35.00 each
Crankshaft bearing cap nut wrench 5-Z-153 $25.00
Re: FS Z TOOLS
Posted: Wed Jan 29, 2020 1:11 pm
by Mark Chaffin
Crankshaft center bearing bolt nut wrench 5-Z-815 $30.00
Driveshaft spool stud nut wrench 5-Z-158 $35.00
Exhaust pack nut wrench 3-Z-524 $35.00
Front and rear spring perch nut speed wrench 3-Z-751 $35.00
Re: FS Z TOOLS
Posted: Wed Jan 29, 2020 1:17 pm
by Mark Chaffin
Generator third brush wrench 5-Z-249 and 5-Z-806 $20.00 each
Oil pan to engine and transmission bolt speed wrench 5-Z-1835 $35.00
Axle housing nut and bolt wrench 5-Z-152 $25.00 each
Rear axle sleeve puller (heavy duty / unknown manufacture) $40.00
Spindle bushing driver (Unknown manufacturer) $25.00
Re: FS Z TOOLS
Posted: Wed Jan 29, 2020 1:19 pm
by Mark Chaffin
Valve spring removal wrench 5-Z-319 $25.00
26/27 wire wheel lug nut wrench T-2839 $30.00
Re: FS Z TOOLS
Posted: Wed Jan 29, 2020 1:43 pm
by Mark Chaffin
Sleeve puller has been sold
One spindle cone wrench sold
Driveshaft stud nut wrench sold.
Re: FS Z TOOLS
by Mark Chaffin
One universal joint wrench sold.
Re: FS Z TOOLS
Posted: Wed Jan 29, 2020 2:05 pm
email sent
Re: FS Z TOOLS
Posted: Wed Jan 29, 2020 2:32 pm
by Mark Chaffin
Front spindle bearing cone wrenches are SOLD OUT
One body bracket holding wrench sold.
Another U Joint wrench sold.
Thanks Scott!
Re: FS Z TOOLS
Posted: Wed Jan 29, 2020 4:37 pm
by tmagill
Mark I sent you a PM
Re: FS Z TOOLS
Posted: Wed Jan 29, 2020 6:19 pm
by Mark Chaffin
26/27 Lug wrench sold.
Spring perch speed wrench sold.
Another Universal joint wrench sold.
Many remaining. Message or call with your needs.
Mark
Re: FS Z TOOLS
Posted: Wed Jan 29, 2020 6:44 pm
by sweet23
E-mail sent
Re: FS Z TOOLS
Posted: Wed Jan 29, 2020 8:32 pm
by Mark Chaffin
Another universal joint wrench sold to Darryl. Only four remaining.
Re: FS Z TOOLS
Posted: Wed Jan 29, 2020 10:50 pm
by Mark Chaffin
Valve spring removal tool has been sold.
Re: FS Z TOOLS
Posted: Thu Jan 30, 2020 1:41 am
by SLinney
I will take body bracket connecting holding wrench 5-Z-212 send me an email
Re: FS Z TOOLS
Posted: Thu Jan 30, 2020 10:27 am
by Mark Chaffin
Pack nut wrench sold to Don. Thanks Don! Thanks MTFCA!
Re: FS Z TOOLS
Posted: Thu Jan 30, 2020 10:32 am
by Mark Chaffin
Body bracket holding wrench pending to Steve. Thanks Steve!
Re: FS Z TOOLS
Posted: Thu Jan 30, 2020 11:37 am
by Mark Chaffin
Pan speed wrench sold.
Main bearing nut wrench sold.
Main bearing bolt wrench sold.
Carburetor and generator mounting wrench sold.
Another universal joint wrench sold.
Thanks Scott!
Re: FS Z TOOLS
Posted: Thu Jan 30, 2020 6:47 pm
by Mark Chaffin
Still have a few remaining. Get them while they last. Contact me with your needs by PM or phone. Mark Chaffin (951) 805-0928
Re: FS Z TOOLS
Posted: Fri Jan 31, 2020 1:16 am
by Mark Chaffin
One universal joint wrench sold to Scott. Thanks Scott!
I have only one universal joint wrench remaining and then they will be sold out.
Re: FS Z TOOLS
Posted: Fri Jan 31, 2020 6:38 am
by Bill Anziani
I'll take the universal joint wrench
Re: FS Z TOOLS
Posted: Fri Jan 31, 2020 2:13 pm
by Mark Chaffin
The Universal Joint to Tail Shaft wrenches are now sold out!
Re: FS Z TOOLS
Posted: Fri Jan 31, 2020 5:44 pm
by Mark Chaffin
I still have the following:
(1) Flywheel to crankshaft bolt wrench $30.00
(5) Connecting rod bolt wrench $25.00
(1) Crankshaft center bearing bolt T wrench $30.00
(1) Driveshaft spool stud nut wrench $35.00
(3) Rear axle bolt and nut wrench $25.00
(1) 3/8 Open end wrench $20.00
(2) Generator 3rd brush adjustment wrench $20.00
(3) 3/8 "L" wrench / transmission cam hut wrench $25.00)
Re: FS Z TOOLS
Posted: Sat Feb 01, 2020 9:31 am
by Mark Chaffin
All remaining tools listed above are now $20.00 each.
Re: FS Z TOOLS
Posted: Sat Feb 01, 2020 9:43 am
by capewake
Hi Mark
I would like to buy one of the universal joint wrenches please.
Emai sent
Re: FS Z TOOLS
Posted: Sat Feb 01, 2020 9:01 pm
by Mark Chaffin
Re: FS Z TOOLS
Posted: Sat Feb 01, 2020 9:41 pm
by Mark Chaffin
REDUCED PRICE!!!!!!!!!!!!
(1) Flywheel to crankshaft bolt wrench $20.00
(5) Connecting rod bolt wrench $15.00
(1) Crankshaft center bearing bolt T wrench $20.00
(1) Driveshaft spool stud nut wrench $20.00
(3) Rear axle bolt and nut wrench $20.00
(1) 3/8 Open end wrench $15.00
(2) Generator 3rd brush adjustment wrench $15.00
(3) 3/8 "L" wrench / transmission cam hut wrench $15.00)
Purchase several and save on shipping.
