Wanted 26-27 wire wheel hub puller
Topic author - Posts: 16
- First Name: Jim
- Last Name: Bowery
- MTFCA Number: 19036
- MTFCI Number: 14288
Wanted 26-27 wire wheel hub puller.
Jim Bowery
Jim Bowery
- First Name: Greg
- Last Name: Kuhnash
- MTFCA Number: 28086
- MTFCI Number: 21773
Re: Wanted 26-27 wire wheel hub puller
Jim I sure hope you find one.
I need one also thinking if you get one I could rent it?
I’ve got one stuck on my pick up. Hope to see you at Marietta in a month.
Greg
Greg
“I don’t like nice people. I like tough, honest people”. - Woody Hayes
- First Name: Henry
- Last Name: Lee
- MTFCA Number: 479
A good three jaw has always worked for me. Strike the end after setting tension and they all come loose.
Just trying to Help,
Hank
Hank
- First Name: Joe
- Last Name: Kowalczyk
- MTFCA Number: 49558
- MTFCI Number: 24878
I use a cheap three jaw from Harbor Freight, works GREAT!
Regards,
Joe Kowalczyk - 1923 Touring, 1913 Speedster, 1913 Runabout
Email: havnfun@cableone.net
(208) 870-3099
(208) 870-3099
- Last Name: Hjortnaes
- MTFCA Number: 28762
- MTFCI Number: 22402
I can't pull a picture over.
I modified a Pittman Arm Puller and it works great. They come in 2 sizes and you need the larger one. You will need to grind off about 1/4 inch of the fingers so it will fit on the hub. Don't think you will find a Model T puller. You would have better luck finding a 2 carat diamond for $10.
- MTFCA Number: 14972
- MTFCI Number: 15411
The Ford puller comes around now & then - there is also an aftermarket Model A hub puller that works. Consider the substantial weight of this puller, it clearly indicates that that axle nut needs to be drawn up TIGHT !
- First Name: John T
- Last Name: Tannehill III
- MTFCA Number: 49460
Steve I knew you’d have one ...maybe 2. Ha
- First Name: Greg
Tried a pitman arm puller, ruined it. Bought another and reinforced it by welding a heavy piece on it, sill opened up. My hub is really stuck.
Greg
Greg
Questions, is it the front or rear hub? Is the wheel off the hub or are you trying to remove the hub from the wheel? If it is the latter I suspect it’s the front hub. What happens over the years dirt & rust get into the space between the wheel & hub and packs it tight. I have had that experience. For that you can lay it front down on blocks and with 2 crow bars opposing each other rock the hub back and forth to wedge it out. As a side note I took a 3200 psi pressure washer and tried to hit between the wheel and hub to remove & soak any of the debris caught in there. I haven’t had an issue on the rear wheels.
