Slotted Head #8 Wood Screws Free You Pay Shipping
Topic author - Posts: 277
- First Name: Rodger
- Last Name: Erickson
- * REQUIRED* Type and Year of Model Ts owned: 1920 Speedster
- MTFCA Number: 32062
I inherited about 20 lbs of #8 1 1/4" slotted head wood screws. Most of them have surface rust. These are quite old, and look a lot nicer than the phillips head screws they sell at Home Depot. If anyone wants some of them lease let me know, you pay mailing costs and they're yours. Thanks for looking.
- Last Name: Willams
- * REQUIRED* Type and Year of Model Ts owned: '09 Roadstr, '12 Touring, '26 Fronti Speedster
- MTFCI Number: 20566
Re: Slotted Head #8 Wood Screws Free You Pay Shipping
Roger: Hi From Thawing In Iowa! I could sure use a couple of lbs if available? Thanks John
- First Name: Bob
- Last Name: McDaniel
- MTFCA Number: 28428
Put me down for about 3 pounds or so. I looked everywhere for some like that about 15 years ago and bought what I could find but have used almost all of them and have a need for more so this will save a lot of searching. I will send you the address but for postage costs the zip is 46947 here. Let me know how and where to send payment.
Those are what are known as long threads here. A normal 1 1/4' screw would have some plain shank under the head. Round heads like those are harder to find than countersunk ones, but then they are not used so much either.
I have reached the conclusion that I am never going to use all the slot head screws I have accumulated, so I have been bagging them up into clear plastic ziplocks and selling them at swap meets. At $2 a packet, with varying numbers depending on size, metal type, head shape, plating etc, They sell well. I even have 12g 3/4" countersunk head brass screws which suit early T steering wheels. Perhaps the weirdest ones are 3g, 1 1/4" nickel plated round heads.
- First Name: Daniel
- Last Name: Snell
- * REQUIRED* Type and Year of Model Ts owned: 1909 Touring, 1924 Touring, 1925 Roadster Pickup, 1921 Touring
- MTFCA Number: 31662
- MTFCI Number: 23677
- Board Member Since: 2014
I would like to take 1/2 lb of these screws please.
Daniel Snell
10014 Raechel Ln
Boerne, Texas 78006
Daniel Snell
10014 Raechel Ln
Boerne, Texas 78006
- First Name: Lester
- Last Name: Husted
- * REQUIRED* Type and Year of Model Ts owned: 20
I would like a pound of the # 8 if you have any left. Let me know what the shipping is. Mike Husted 1553 W. Sunnyside Rd. Idaho Falls , Id.
83402 Thankyou
83402 Thankyou
- First Name: Joe
- Last Name: Lucas
- * REQUIRED* Type and Year of Model Ts owned: 1927 Tudor
- MTFCA Number: 50498
What an outstanding and generous gesture, Rodger.
I'm screwed up enough but wanted to say that I appreciate the kindness of your offer.
None of us is as smart as all of us.
- First Name: Randy
- Last Name: Fisher
- * REQUIRED* Type and Year of Model Ts owned: 1916 Touring
- MTFCA Number: 50319
- MTFCI Number: 23917
I will take 2 lbs if they are available. Thanks
Just to give you an idea I can fit 4 Lbs and some change in a small flat rate box. There's still enough to go around.
- First Name: William
- Last Name: Rathert
- * REQUIRED* Type and Year of Model Ts owned: 1909, 1915, 1917, 1926
I also would like 1 or 2 lbs if still available. Thanks so much.
I still have about 5 pounds left of these but they're rusty. You might be able to clean them up with a wire wheel. If you want to give it a try and let me know.
- Last Name: Dewey
- MTFCI Number: 19936
These screws are a great deal. I took my "baggie" of them and put them in a sand-filled tumbler--they cleaned up quickly and now look great! thanks Rodger!
T'ake care,
David Dewey
David Dewey
- Last Name: Vanderburg
- MTFCA Number: 28382
How much for the remaining five pounds? to 08527
William L Vanderburg
1922 Center Door Sedan
If you missed out on the first go around I found about 5 more lbs. of this size wood screw (#8 x 1 1/8") however, these are a little newer and quite a bit less rusty. Same deal as before you pay shipping and they're yours.
I also have maybe 1 or 2 lbs of 8 x 32 Slotted Oval Head Machine Screws, made of steel, 3/16 length, if anyone is interested. Again, just pay shipping.
Thanks for looking.
Thanks for looking.
- First Name: Charlie
- Last Name: Coleman
- * REQUIRED* Type and Year of Model Ts owned: 1926 TT C Cab Stakebed Truck
- MTFCA Number: 51002
Hello Roger, could I get a pound or so of each of these screws, Thank You, Charlie
For shipping the Zip code is 95470
I’ll send a pm with the shipping address and I’ll
Need a payment address when you determine the amount.
Thanks again, Charlie
- Last Name: Sanford
- * REQUIRED* Type and Year of Model Ts owned: 14 Touring, 26 Roadster, 27 Roadster
Roger, I will take a flat rate box of the wood screws along with some of the machine screws. My zip code is 75002.
Let me know how to pay for these.
Dennis Sanford
Dennis Sanford
- First Name: Ryan
- Last Name: Snellen
- * REQUIRED* Type and Year of Model Ts owned: 1912, 1919, 20's FrankenT
I'll take 2lbs if the wood screws.
Email sent. Thank you Roger
- First Name: Tommy
- Last Name: Turner
- MTFCA Number: 22626
Rodger, I'd take a pound or so of your wood and a pound or so of the machine screws if you have any left if not, that's OK. I purchased a few lights off of you through the years. You do good work! Just let me know what I owe you and I can send check, Paypal or whatever works for you. Thanks.
Tommy Turner
Tommy Turner
Screws are all spoken for. Thanks.
