1919-1927 Completely Rebuilt Ford Model T Generators With 90 day warranty!
AdminJeff
First Name: Jeff
Last Name: Stevenson
* REQUIRED* Type and Year of Model Ts owned: 1921 Touring
MTFCA Number: 50006
Post by AdminJeff » Thu Dec 26, 2019 3:50 pm
I have 4 (so far) Professionally Rebuilt Ford Model T generators. Fits 1919-1927 cars including TT. These are WAY more fun to rebuild than the ones on Porsche 911's, and I've done many!
$250 exchange shipping INCLUDED anywhere in the USA.90 day, unconditional warranty ALSO included.
PROCESS USED ON ALL REBUILT GENERATORS:
Completely Disassemble & clean
Remove all old wires and disintegrated wrapping on field coils and carefully clean them.
Separate the individual coils. Rewrap each field coil with superior Scotch brand Glass Cloth Electrical tape.
Power up and Check each coil w/ Magnometer for maximum field strength AND polarity
Replace terminal post insulator, washer & post wire, and polish terminal post nuts and bolt or replace as needed.
Reassemble/solder field coils with new post wires, insulators and new terminals.
Clean and rebuild brush holder plate. Replace with new insulators on 3rd brush.
Tap all holes in brush plate with 10-32 thread-chasing tap.
Replace all screws and lock washers.
Replace brush holder screws with new BRASS screws and new zinc coated split washers.
Install new brushes in brush plate.
Pre-Test Armature on growler and check on lathe for straightness on both front and rear shafts.
Clean armature and take off ~10 thou on commutator surface or as needed for perfect brush contact on South Bend Lathe.
Mica undercut commutator ~20 thou.
Commutator final polished with 1500 polishing paper.
Polish & Fit front and back shafts for new sealed ball bearings.
Re-Test Armature on growler for shorts after cleanup.
Paint inside of all exposed surfaces with gloss black enamel
Fit armature into field coils for final clearance as needed.
Check end play of assembled unit.
NOTE: ALL 10-32 and 6-32 screws and split washers in all locations replaced with zinc coated decorative flat-head screws just like were on the unit when new. Brush Terminal screws replaced w/ brass for better conductivity.
RUN-IN TESTING & ADJUSTMENT
Set brush holder plate for neutral/slight positive rotation with +6V.
Set charge rate to 7A. **see note below
Bench test/run in for 30 min at 1700 rpm.
Painted inside and out with gloss black enamel.
Contact me if you want a good generator drive gear pre-installed for you with a new pin) for an additional $10 (while I have them)
Solidly packed in bubble wrap and ship!
**NOTE: Adjustments assume the original Ford Cut-out is used. Final fine-adjustment of 3rd brush (charge rate) may be necessary once you get it depending on your car and accessories and is very easy to do. 5A to 7A seems to work for most applications, esp for touring when the car is driven longer distances. If you only drive short distances, 10A might be better in that case to keep the battery fully charged and this is easily changed by moving the 3rd brush once installed in the car. Fun Projects Voltage regulators require different charge rates but can be easily set when this generator is installed in the car using the instructions that come with the regulator. These voltage regulators are very worthwhile upgrades.
The Rear Oiler is not used as these generators use permanently sealed bearings.
These come with a 90 day unconditional warranty included (which starts when you get it).
Assistant WebSite Admin
Voltage Regulators, Starter & Generator Repair
www.modeltregulators.com
www.modeltstarters.com
First Name: Henry
Last Name: Lee
MTFCA Number: 479
Re: 1919-1927 Completely Rebuilt Ford Model T Generators With 90 day warranty!
Post by Henry K. Lee » Thu Dec 26, 2019 3:58 pm
Super Nice Job, Super Jeff!
AdminJeff
First Name: Jeff
MTFCA Number: 50006
Post by AdminJeff » Thu Dec 26, 2019 6:27 pm
Thanks Hank!
1 sold. 3 left. Thanks Robert!
Jeff
abcarswell
First Name: Bruce
Last Name: Carswell
* REQUIRED* Type and Year of Model Ts owned: 1924 Model TT
Post by abcarswell » Thu Dec 26, 2019 8:22 pm
PM sent
AdminJeff
First Name: Jeff
MTFCA Number: 50006
Post by AdminJeff » Thu Dec 26, 2019 10:08 pm
2 generators left. One w new field coils, one without.
Thanks Erik!!
Jeff
AdminJeff
First Name: Jeff
MTFCA Number: 50006
Post by AdminJeff » Fri Dec 27, 2019 3:17 pm
I have 1 generator left. Gen w new field coils is now SOLD.
AdminJeff
First Name: Jeff
MTFCA Number: 50006
Post by AdminJeff » Fri Dec 27, 2019 3:22 pm
All my rebuilt generators are now spoken for. If you have one that needs to be rebuilt per the same specs above, send me a note and we can work something out. I can now turn these out in less than a week.
Jeff
Tbz4u
Last Name: Weitzel
* REQUIRED* Type and Year of Model Ts owned: 27 coupe,23 touring 14 speedster WILD CHERRY 2 1909 touring 27 roaster
MTFCA Number: 22631
Post by Tbz4u » Thu Jan 02, 2020 11:04 pm
U da man 👍
Fordfever
Last Name: Metzentine
* REQUIRED* Type and Year of Model Ts owned: 23 touring
Post by Fordfever » Sun Feb 02, 2020 12:31 am
Evening Jeff- was reading your description on your gen rebuilds, nice! Do U do starters too? Thk u , Mike.
AdminJeff
First Name: Jeff
MTFCA Number: 50006
Post by AdminJeff » Sun Feb 02, 2020 8:27 am
I do! I now have all the tooling to do both now. And I can also do 12v conversations. I also replace the worn out Babbitt bearing in the starter snout with a bronze bushing on the starters and use the same meticulous rebuild method on the starters as I use on the generators. There's just a lot more work on starters because of the snout rehab.
I have one rebuilt generator left and dozen more of each on my shelf ready to be rebuilt and can turn them around in about a week. The starters are a ton of work to do right, and most of them need new field coils as rewrapping isn't normally an option. The generators not so much.
Exchange prices
Generator: $250 (assumes rewrapped field coils)
Starter: $350 (assumes new field coils)
Outright purchase (no exchange, no core required)
Starter: $390
Generator: $290
Jeff
Fordfever
Post by Fordfever » Sun Feb 02, 2020 10:25 am
Thk u, will be needing both in near future & I have cores too, Mike.
Scott C.
Last Name: Clements
MTFCA Number: 49592
Post by Scott C. » Sun Feb 02, 2020 11:04 am
I am curious about your " And I can also do 12v conversations." Can you tell us a little more about that?
dobro1956
First Name: Donnie
Last Name: Brown
MTFCA Number: 49575
Post by dobro1956 » Sun Feb 02, 2020 11:56 am
I'm also interested in the 12 volt conversions. I assume you mean 12 volt starters.??
I'm getting ready to put a starter in the speedster project. A 12 volt starters would be great.
MTFCA Number: 121
MTFCI Number: 16310
Post by Original Smith » Sun Feb 02, 2020 9:41 pm
No one need a 12Volt starter if you electrical system is in good condition.
Scott C.
Last Name: Clements
MTFCA Number: 49592
Post by Scott C. » Sun Feb 02, 2020 11:05 pm
Still curious about your 12 volt conversations??
AdminJeff
First Name: Jeff
MTFCA Number: 50006
Post by AdminJeff » Tue Feb 04, 2020 8:41 am
I split this 12v discussion as it's worth it's own topic
https://www.mtfca.com/phpBB3/viewtopic. ... 958#p75958
Mark Chaffin
Last Name: Chaffin
MTFCA Number: 31705
Post by Mark Chaffin » Tue Feb 04, 2020 5:55 pm
Very nice work Jeff!
