WTB '25 pick up fender mounts
sweet23
First Name: Darryl
Last Name: Bobzin
MTFCA Number: 27211
Post by sweet23 » Sun Feb 23, 2020 9:09 am
I am in need of two '25 pickup rear fender mounting irons. Or one in good enough shape to use for a pattern to make them. Thanks, Darryl
HornsRus
First Name: Charley
Last Name: Shaver
Re: WTB '25 pick up fender mounts
Post by HornsRus » Sun Feb 23, 2020 9:53 am
i have lots of them same as touring fender mounts.i can grind some off for you.$ 30.00 PP charley
MTFCA Number: 14972
MTFCI Number: 15411
Post by RajoRacer » Sun Feb 23, 2020 10:51 am
Original '25 p/u box fender irons have a gradual taper where they thread into the receptacle that is riveted to the side of the box unlike the touring which are straight. I've owned originals.
sweet23
First Name: Darryl
Last Name: Bobzin
MTFCA Number: 27211
Post by sweet23 » Sun Feb 23, 2020 12:47 pm
Thank you Charley, I will see if I can find pick up irons first.
23ford
First Name: Warren
Last Name: Webb
Post by 23ford » Sun Feb 23, 2020 1:16 pm
You can make some with a lathe and mill as someone did a few in the 70's. :roll:
HornsRus
First Name: Charley
Last Name: Shaver
Post by HornsRus » Sun Feb 23, 2020 5:06 pm
i checked the touring ones they are straight thread. but what would be the point of a tapper on the pickup,they do the same thing hold the fender.i checked the thread in the roadster top bracket ,straight thread.anybody?????????????????????????? charley
MTFCA Number: 14972
MTFCI Number: 15411
Post by RajoRacer » Sun Feb 23, 2020 5:14 pm
Charlie - the P/U irons are straight thread BUT right where it goes into the bracket, they have a distinguishable taper out about an inch then the round iron begins.
HornsRus
First Name: Charley
Last Name: Shaver
Post by HornsRus » Sun Feb 23, 2020 5:46 pm
so then the bracket on the bed would be the same as the touring !!!!!!!!!!!! charley
SurveyKing
First Name: Daniel
Last Name: Snell
MTFCI Number: 23677
Board Member Since: 2014
Post by SurveyKing » Sun Feb 23, 2020 6:07 pm
RR 25 Pickup Fender Bracket
Rear 24 Touring Fender Bracket
These are photos of both a bracket mounted on my 25 Pickup and a 23-25 Touring bracket
SurveyKing
First Name: Daniel
Last Name: Snell
MTFCI Number: 23677
Post by SurveyKing » Sun Feb 23, 2020 6:10 pm
Visually they both seem to be the same, without removing the fender to check the threads.
sweet23
First Name: Darryl
Last Name: Bobzin
MTFCA Number: 27211
Post by sweet23 » Sun Feb 23, 2020 6:33 pm
I think what is being said is that the threads are the same, touring or pickup, but the pickup iron has a taper before the treads instead of the abrupt diameter change the touring iron has. Anyway, does anyone have one or a good drawing of one so I can make a pair?
sweet23
First Name: Darryl
Last Name: Bobzin
MTFCA Number: 27211
Post by sweet23 » Sun Feb 23, 2020 7:58 pm
Is this the rear fender iron I am looking for?
a fender iron.jpg (6.93 KiB) Viewed 540 times
keen25
First Name: Eric
Last Name: Keenan
Post by keen25 » Sun Feb 23, 2020 8:13 pm
Yes,that is the one. They do repro them but price is high. I just made a pair to replace a home made set on a 25 pickup. I have on that I did not thread correctly that I can send If you pay the shipping.
MTFCA Number: 14972
MTFCI Number: 15411
Post by RajoRacer » Sun Feb 23, 2020 8:30 pm
Yes, they are Charlie.
SurveyKing
First Name: Daniel
Last Name: Snell
MTFCI Number: 23677
Post by SurveyKing » Sun Feb 23, 2020 8:59 pm
I can say that the fender brackets in the first photo are from original beds as one was on the pickup bed when I got it and the other came off another pickup bed, both were the same. They both appear identical to the stock '23-24 Touring, not sure what the purpose of the gradual taper would be as shown in the reproduction by Darryl. Can you tell us Darryl?
HornsRus
First Name: Charley
Last Name: Shaver
Post by HornsRus » Sun Feb 23, 2020 10:01 pm
looks like was wrong i thought you needed the casting riveted to the bed.now that i think about it the hever fender mont must be for sacks of feed,ha,ha. charley
sweet23
First Name: Darryl
Last Name: Bobzin
MTFCA Number: 27211
Post by sweet23 » Sun Feb 23, 2020 11:03 pm
After looking at the photos in Bruce's book that begin on page 371, the fender iron looks tapered like the photo of the reproduction fender iron I posted. I have not been able to find them listed in any of the Ford parts books from '25 or '26. So back to my original listing,,,,,,, Does any one have any they are willing to part with ?
MTFCA Number: 121
MTFCI Number: 16310
Post by Original Smith » Mon Feb 24, 2020 11:16 am
The p/u fender irons are indeed tapered. I loaned an original to Gator Gould many years ago, and I think he reproduced them. I've owned two original '25 pickups, and they both have the tapered irons.
sweet23
First Name: Darryl
Last Name: Bobzin
MTFCA Number: 27211
Post by sweet23 » Mon Feb 24, 2020 11:35 am
Thank you Larry, I am still in need of original to buy or copy.
