WTB 12 Tooth Pinion
Topic author - Posts: 83
- Last Name: Houston
- * REQUIRED* Type and Year of Model Ts owned: 13,14,19,21,&etc
- MTFCA Number: 32227
- MTFCI Number: 23901
WTB 12 Tooth Pinion
I am wanting to buy a good 12 tooth pinion gear that I can use with the stock 40 tooth ring gear in my 1924 Coupe, to make it a 3.33/1,at a reasonable price. Hopefully someone has one sitting around extra that can help me with this project on(almost)daily driver & tour car.-dhouston66.dh@gmail.com {MTFCA#55549}
Thank You---Have a good day&Take care---David {POPS}
- First Name: Herbert
- Last Name: Chaffin
- * REQUIRED* Type and Year of Model Ts owned: 1909 touring, 1911 touring, 1913 roadster, 1914 touring
- MTFCA Number: 227
Re: WTB 12 Tooth Pinion
CHAFFINS MAKES THEM
- MTFCA Number: 227
CHAFFIN'S MAKES THEM
- First Name: Bruce
- Last Name: Compton
- * REQUIRED* Type and Year of Model Ts owned: 1921 Coupe, 1925 Coupe
David : I'm sure you already know, but you can't use a stock original 40 tooth ring gear. You need the recessed 40 tooth ring gear. I tried to do this mod on my '25 coupe and just couldn't get a combination that didn't howl. I had at least 3 different 12 tooth pinions and 2 different crowns and every combination howled. I must have had the rear end out 10 times before I gave up and went back to the stock set up. Good luck in your attempt. Bruce
Hello : First- THANK YOU -CHAFFIN'S for your reply on the 12 pinion!!
Bruce I do appreciate the input on info so I need to change my request to a -12 tooth pinion &! ring gear?? Right now I believe my cash flow holds me to a gear that is rusted,maybe a little over past best but can be used to get the car usable to see if the 3.33/1 will work and not too of a high of a gear. that is why I would like to find one at a really good price for testing for
I know most of you "T" people have one sitting on your back shelve or "MAYBE" to be used latter box/shelves.with some rust and pits that I can use for my use. Miss match --No sweat!! Come on fellow members help me out
THANK YOU FOR ANY HELP-DAvid--POPS---Have a good day&Take care---
dhouston66.dhATgmail.com
Hello fellow "T" people--Keep looking in your spare parts bins Thank you pops
- First Name: Ed
- Last Name: Archer
- * REQUIRED* Type and Year of Model Ts owned: 1909 replica Transcontinental race car, 1915 2 man race car, 1918 American bodied speedster
- MTFCA Number: 19
- Board Member Since: 2009
I have a recessed 40 tooth ring gear that appears to be NOS. Got the Ruckstell stamp on it. $150.00 plus shipping.
ED aka #4
ED aka #4
still looking----POPS
- First Name: Don
- Last Name: Kirtley
- * REQUIRED* Type and Year of Model Ts owned: 13 and 16 touring, 18 and 20 coup, 20 tudor
- MTFCA Number: 23703
- MTFCI Number: 23153
David I emailed you about the pinion gear. Give me a call. Don
- First Name: Rich
- Last Name: Huggins
- * REQUIRED* Type and Year of Model Ts owned: 1923 touring- 1922 deverley truck -1922 center door
- MTFCA Number: 50661
wanted 40 tooth recess ping gear dose any one have
