Door Hinge Mounting Bolts/Nuts
SurveyKing
First Name: Daniel
Last Name: Snell
MTFCI Number: 23677
Board Member Since: 2014
Post by SurveyKing » Tue Mar 10, 2020 11:14 am
I would like to buy used or NOS door hinge mounting bolts and nuts, enough for all three doors. This is for the 1915-1924 style hinges. These go through the door posts on both sides of the hinges. Email or message me with what you have.
grizzsnell@gmail.com
Last Name: Kuehn
MTFCA Number: 28924
Re: Door Hinge Mounting Bolts/Nuts
Post by John kuehn » Tue Mar 10, 2020 1:20 pm
Saw you add. I found some door bolts at Ace hardware that were almost if not identical for my 21 Touring. There were 2 original that were still in the remains of the body that I used for a match.
SurveyKing
First Name: Daniel
Last Name: Snell
MTFCI Number: 23677
Post by SurveyKing » Tue Mar 10, 2020 4:00 pm
John, thanks for that. Perhaps I could find some new ones but at this point, I do not even have one original to use as a go by to get the right size.
Last Name: Kuehn
MTFCA Number: 28924
Post by John kuehn » Tue Mar 10, 2020 5:18 pm
Hello again
Here is a pic of what the screw looks like that’s used on T open car door hinges. I have a 21 Touring that I restored and used new screws for the hinges. In the pic is a extra hinge that has an original hinge screw in it. I saved it as the others were shot.
You can take your hinge to a hardware store and use it to match some screws to use with it.
As you can see the originals were slot headed bolts that had counter sunk heads that would flush fit in the hinge holes.
Seems like there are some that you use wood screws with the same head in some of the hinge holes.
Hope this helps.
John
SurveyKing
First Name: Daniel
Last Name: Snell
MTFCI Number: 23677
Post by SurveyKing » Tue Mar 10, 2020 6:59 pm
Hi John, can you give me the length of that screw?
Last Name: Kuehn
MTFCA Number: 28924
Post by John kuehn » Tue Mar 10, 2020 7:41 pm
Hi again
The length of the screw in the pic is 1 1/2”. If you look in the picture you can see it used a square head nut. I can’t remember if the hardware store (Ace) had square head nuts but seems to me you could use hex head nuts anyway. I did use flat washers though because they were on there originally. One door on my car had just one screw all the way through the wood. And the rest were wood screws. You need to use at least one screw that goes all the way through the body pillar to keep the door from eventually sagging. And always pre drill the holes where your using wood screws as it makes it easier to install the screw. Always drill a little smaller than what the screw is. The screws that are avaliable now are all thread probably most of the time now. If they are longer than 1 1/2” it won’t hurt. Buy some to see for sure if that’s the right length for your car.
Hope this helps
John
SurveyKing
First Name: Daniel
Last Name: Snell
MTFCI Number: 23677
Post by SurveyKing » Wed Mar 11, 2020 7:01 am
Thanks John, very good information. I will go to ACE if I cannot find any originals.
SurveyKing
First Name: Daniel
Last Name: Snell
MTFCI Number: 23677
Post by SurveyKing » Wed Mar 11, 2020 3:45 pm
Still looking for originals or NOS bolts/nuts.
First Name: Henry
Last Name: Lee
MTFCA Number: 479
Post by Henry K. Lee » Wed Mar 11, 2020 4:04 pm
Daniel how many do you need total with the nuts?
I have them in 1/4” x 20 thread zinc plated.
First Name: Henry
Last Name: Lee
MTFCA Number: 479
Post by Henry K. Lee » Wed Mar 11, 2020 4:05 pm
They are 2” in total length
