Original Ammeter FS
Mark Osterman
Last Name: Osterman
Original Ammeter FS
Post by Mark Osterman » Wed Mar 11, 2020 11:00 pm
Nice original ammeter. The surround is a little beat up and there is only one tab, but once it’s screwed into the instrument panel it would be secure. $40 plus post.
allan56
Last Name: Hesch
Board Member Since: 2010
Re: Original Ammeter FS
Post by allan56 » Mon Jun 15, 2020 11:48 pm
Hi Mark, do you still have your ammeter for sale? I've never seen one in person as my car (1924) has a modern small ammeter and adapter plate, so I don't know what you mean by "only one tab". And, the ammeter works normally? Thanks! Allan Hesch, Eugene Oregon, 541-579-3000
Piewagon
Last Name: Regan
MTFCA Number: 0
MTFCI Number: 77
Post by Piewagon » Thu Jun 18, 2020 2:18 pm
The back side of the outer ring is held to the meter housing via bent over tabs that hold the ring on when the meter is not mounted in the car. When mounted the tabs serve no function typically. On your '24 the only part of this meter that would be visible to driver or passengers is the inner meter face and the shiny painted part of the ring portion where the glass sits. That part goes through the dash from behind thus hiding the portion of the meter that has dings in it. The outer ring portion is not going to show assuming this meter is mounted in your car using an original stock mount. Some original meters are in perfect working order. There is no adjustment to these meters typically so you won't know how "bouncy" it is or how accurate it is. If you were local I could test it on my Hewlett Packard digital high current source and tell you exactly how accurate it is (none were perfect) and you soon learn what is normal and what is not normal with your electrical system if your meter is anywhere in the realm of +/- 5% accurate at full scale.
Hope this helps.
MTFCA Number: 121
MTFCI Number: 16310
Post by Original Smith » Fri Jun 19, 2020 11:26 am
Yours looks like it could be a Sterling. There are two types. The early style says Sterling, and the later one says SMC.
George Hand
Last Name: Hand
MTFCA Number: 28114
MTFCI Number: 21834
Post by George Hand » Fri Jun 19, 2020 11:37 am
Mark, Have you sold your ammeter, if not I will take it. George Hand, Preble NY
ModelT46
First Name: Darel
Last Name: Leipold
MTFCA Number: 823
MTFCI Number: 953
Post by ModelT46 » Fri Jun 19, 2020 6:07 pm
since that one is sold, I would like to show the one I have for sale. nice and clean. $40 and $8 shipping boxed. the needle shows true when upright. I scaned this one so it was face down.
Darel Leipold send email if interested. Thanks to the poster for this thread.
amp meter 1919-25070.jpg (89.2 KiB) Viewed 649 times
ModelT46
First Name: Darel
Last Name: Leipold
MTFCA Number: 823
MTFCI Number: 953
Post by ModelT46 » Fri Jun 19, 2020 6:11 pm
I have new rings for this one, if you wanted a NOS ring/rim I would install one )no extra cost)
ModelT46
First Name: Darel
Last Name: Leipold
MTFCA Number: 823
MTFCI Number: 953
Post by ModelT46 » Fri Jun 19, 2020 8:30 pm
Mine is sold. Watch. Classifieds,I may have another one.
ModelT46
First Name: Darel
Last Name: Leipold
MTFCA Number: 823
MTFCI Number: 953
Post by ModelT46 » Sat Jun 20, 2020 3:14 pm
I have another. It is a Sterling. Nice face and ring. Back is dented, but not harmed, but i will stand back of it. Original nuts. since tha back is a bit more used looking, it is $40 postpaid.
Darel
ModelT46
First Name: Darel
Last Name: Leipold
MTFCA Number: 823
MTFCI Number: 953
Post by ModelT46 » Sat Jun 20, 2020 3:17 pm
If you are not satisfied with any of my old stuff, just email me. I will take care of it as best.
Darel
Budreau
First Name: Chad
Last Name: Budreau
MTFCA Number: 377
Post by Budreau » Mon Jun 22, 2020 7:29 pm
Darel,
I'm sending you an email. May be interested. Thanks. Chad
[b][size=130]Chad Budreau[/size][/b]
1923/24 Tudor | 1915 Speedster | 1924 Depot Hack | 1925 Touring
ModelT46
First Name: Darel
Last Name: Leipold
MTFCA Number: 823
MTFCI Number: 953
Post by ModelT46 » Tue Jun 23, 2020 4:55 pm
STILL AVAILABLE.
Thanks, Darel Leipold
ModelT46
First Name: Darel
Last Name: Leipold
MTFCA Number: 823
MTFCI Number: 953
Post by ModelT46 » Thu Jun 25, 2020 1:34 pm
sold........
