New and correct year parts throughout including switch except the brass knurled knobs are old ones, and I bought a set of 10 OLD coil contact springs including the bottom one as they're the good ones. I machined the proper size hex nuts for holding the porcelain assembly's together. All parts and pieces purchased from Lang's. Marine varnish finish. I used this box for a year of trouble free touring on my 1913 T. Coils not included. You have to shim the coils in order for them to sit snug. You can have the cardboard shims I used. You will NOT have to alter the holes in the firewall for the 10 porcelains to stick through. I modified the holes that were pre-drilled in the coil box, filled them and modified the coil contacts, re-positioned the holes, making for trouble free installation, operation, and function. Correct latches. I stress/aged the nuts and washers that hold the box to the firewall to look old. Steel brackets on back painted to look like brass plating. I'm selling this for only what I paid for the parts. I found and restored an original Heinze box and coils for my car, so that's the only reason I'm selling this unit.
Price is $670.00.
A great opportunity to get a nice coil box without having to restore one! Shipping is extra. Thanks for looking!
FS- 1912-13 KW wood coil box new replica reproduction
Topic author - Posts: 343
- First Name: Darren
- Last Name: Wallace
Last edited by Darren J Wallace on Fri Mar 13, 2020 4:47 pm, edited 5 times in total.
Re: FS- 1912-13 KW wood coil box new replica reproduction
More pics of the interior and rear
back to the top, any interest?
