I have a Classtique seat back upholstery assembly for a 23 runabout that I didn’t install correctly. When I took the car to an upholstery shop to fix what I screwed up they didn’t want to use it so I had to buy a second assembly.
This has staple holes where I installed it and a small section cut out where a corner overlaps. This could be fix with a patch of the same material sewn it. Good for someone on a budget or could be repurposed a for a rare or speedster.
$150 plus post
Classtique Upholstery FS
Topic author - Posts: 1011
- Last Name: Osterman
- First Name: Shane
- Last Name: Lach
- * REQUIRED* Type and Year of Model Ts owned: 1927 Tudor and 1921 speedster in progress
Re: Classtique Upholstery FS
Could you take some height and width measurements to the Staples and between the cutouts?as well as the ends
Still have this upholstery for sale. Might be for a speedster or economical solution for a low cowl roadster.
