WTB - Old Worn Upholstery Tacks
RustyFords
First Name: Don
Last Name: Allen
MTFCA Number: 50001
Post by RustyFords » Thu May 14, 2020 9:20 pm
Looking for a bunch of old upholstery tacks that are showing wear and age...for the worn leather upholstery I'm about to install in my 24 Touring.
1924 Touring
Last Name: Seth
Re: WTB - Old Worn Upholstery Tacks
Post by perry kete » Fri May 15, 2020 7:21 am
You may want to try soaking new shinny tacks in vinegar over night or in a mild acid solution to make them looked aged and then neutralize the acid with a soda solution. You could scuff them with a wire brush.
RustyFords
First Name: Don
Last Name: Allen
MTFCA Number: 50001
Post by RustyFords » Fri May 15, 2020 8:01 am
Thanks Dennis
1924 Touring
Last Name: Juhl
MTFCA Number: 50297
MTFCI Number: 24810
Post by Oldav8tor » Fri May 15, 2020 6:41 pm
Geez, wish I had known. I just threw out a bunch. Are you talking about flat head tacks or the more decorative ones?
1952 Willys M38a1 Jeep
MTFCA Number: 121
MTFCI Number: 16310
Post by Original Smith » Sat May 16, 2020 10:56 am
Are you looking for upholstery buttons? A tack is much different.
RustyFords
First Name: Don
Last Name: Allen
MTFCA Number: 50001
Post by RustyFords » Sat May 16, 2020 12:23 pm
Either one would work for me.
1924 Touring
RustyFords
First Name: Don
Last Name: Allen
MTFCA Number: 50001
Post by RustyFords » Sat May 16, 2020 12:24 pm
1924 Touring
Post by Allan » Sun May 17, 2020 4:25 am
Don, The cut, blued tacks used to nail upholstery down to a wooden base have a flat head and the shank is square and tapers to a sharp, cut point. What we call upholstery tacks are used to nail trim strips down over the cut tacks used to fix the material. These have a domed head of approx 3/8' diameter. I have new old stock cut, blued tacks, but had to wire buff much of the black paint of some upholstery tacks to get some distressed ones to use on Henrietta.
Hope this clears up the confusion.
Post by TRDxB2 » Sun May 17, 2020 10:57 am
Cut tacks, flat head tacks or more decorative ones, upholstery tacks, buttons ... a picture of what your looking for would eliminate more questions and get you what you need
RustyFords
First Name: Don
Last Name: Allen
MTFCA Number: 50001
Post by RustyFords » Sun May 17, 2020 11:02 pm
No photo needed if I've said I'll gladly take any old upholstery related buttons/tacks/etc/etc. I'm just looking for worn upholstery fasteners.
1924 Touring
Erik Johnson
First Name: Erik
Last Name: Johnson
Post by Erik Johnson » Mon May 18, 2020 1:01 pm
Terminology - upholstery tacks vs upholstery nails:
Many folks and vendors use the terms "upholstery tack" and "upholstery nail" interchangeably. However, an upholstery tack and an upholstery nail are actually two different things.
Upholstery tacks are used to fasten the material to the underlying wooden frame. Available in various sizes, they are small and crude, flat head cut nails and are typically "blued." They are "sterilized" because, years ago, upholsterers would hold them in their mouths. Upholstery tacks are typically not conspicuous when viewing the finished product, regardless if it is an armchair, sofa or antique car upholstery, because they are either covered or on the underside of the piece. Most professional upholsterers today use staple guns, not tacks.
"Tack spitting" for those who are interested:
https://www.youtube.com/watch?v=UDCPRTmslsA
https://www.youtube.com/watch?v=OFIN7k9I_Gg
https://www.youtube.com/watch?v=oCviBqqWAv0
Upholstery nails (aka furniture nails) are visible, decorative nails. For example, on pre-1923 Model T roadsters and tourings, upholstery nails are used to fasten the binding/trim on the armrests and seat backs.
I have pointed out upholstery nails in the photo below. (The upholstery tacks which actually hold the upholstery in place, are under the binding.)
Norman W
First Name: Norman W.
Last Name: Woolley
Post by Norman W » Mon May 18, 2020 2:36 pm
I restored a 1911 Ford and still have the old ones if you are interested you can have them for the postage.
My email is normanww@gmail.com send my your address and you get lots of tacks.
RustyFords
First Name: Don
Last Name: Allen
MTFCA Number: 50001
Post by RustyFords » Mon May 18, 2020 8:31 pm
I'd love to have them Norm...thank you.
Sending an email now.
1924 Touring
