Small drum axle housing smooth no ribs on the ends 15-18????style
has new brake cams levers and bushings
Installed otherwise bare
Cleaned straight in primer
Asking $75 for the pair L&R
1920/21 engine was a running motor last year but had broken drum now i found a replacement has crank rods pisons front cover pan trans flywheel magneto works
lifters and valve holes reamed 1 size up was my spare engine no longer need it so everything shoild be good now but will need cam and cam gear $325
You find rides xan store
