WTB Driving plate 25 back
Topic author - Posts: 99
- First Name: Eric
- Last Name: Keenan
- * REQUIRED* Type and Year of Model Ts owned: 1923 coupe, 1925 TT, 1926 coupe, 1925 Tudor, 1925 pickup, 1926 fordor
I am looking for a good 1925 back driving plate. thank you Erick
- First Name: Joe
- Last Name: Bell
- MTFCI Number: 24066
Re: WTB Driving plate 25 back
Are you looking for the one that used the screws instead of bolts and for the improved narrow brake drum with the removable lugs?
- First Name: Eric
- Last Name: Keenan
I have the narrow brake drum with the removable lugs, also the ones with the screws. thank you Erick
- First Name: ROBERT
- Last Name: BERGSTADT
- MTFCA Number: 1575
there are two types one with the flat bottom for 1925-27 and one with a lip on the bottom for 1909-24, I have one late one for sale and many early ones, Bob
- First Name: Eric
- Last Name: Keenan
Hi Bob, I need the one with the lip for the smaller 25 back drum but it needs to have the same bolt pattern / bolt circle as the wider brake drum as the 26 / 27. thank you. Erick
- First Name: Joe
- Last Name: Bell
All the ones I have tore down have long gated holes with screw headed bolts for clearance, if you use regular bolts your socket will not fit. The 26-7 style is made to be centered with the big drum, so all you need to do with the earlier driven plate is long gate the holes to make the pattern smaller diameter. Hope this helps.
- First Name: Eric
- Last Name: Keenan
Thank you Joe, I may need to do that.
