Two rebuilt and tested Wheeler Schebler carbs
Topic author - Posts: 584
- First Name: Bruce
- Last Name: Compton
- * REQUIRED* Type and Year of Model Ts owned: 1921 Coupe, 1925 Coupe
I have two identical rebuilt and tested Wheeler Schebler carbs designed for the Model T Ford. They are very similar to the Stromberg OF but provide a bit better top end. Also like The OF, they are a set and go carb with no need to constantly adjust the mix for varying load and speed conditions. Not as common as the OF but every bit as good. These carbs have been ultrasound cleaned, had the throttle shafts repaired, their floats pressure tested and have been test ran. Initial settings are 1 3/4 open for the idle jet and 2 3/4 for the high speed jet. Both are set for my engine. Either carb is $450.00 including shipping to continental USA or Canada.
- MTFCA Number: 52564
Re: Two rebuilt and tested Wheeler Schebler carbs
These two and the one I have are the only ones I have seen with the straight neck for the intake, they can use the standard hot air pipe. These also have the enriching valve.
1920 Dodge touring
1920 Dodge touring
