WTB Lugs for Demountable rim
Topic author - Posts: 86
- First Name: David
- Last Name: Herring
- * REQUIRED* Type and Year of Model Ts owned: 13 Touring, 14 roadster
- MTFCA Number: 22001
- MTFCI Number: 24521
Wanted 4 lugs for demountable rim, not sure of make but it has only one locating bracket on the rim with a notch, not able to upload a picture for some reason[image][/image]
- First Name: David
Re: WTB Lugs for Demountable rim
- MTFCA Number: 14972
- MTFCI Number: 15411
More than likely a Kelsey rim - I have a coffee can full but there are a couple different profiles - I'll post a couple photos tomorrow.
- First Name: David
That will be great many thanks
If they are the U shaped lugs needed for a Kelsey rim, you will also need the nuts with the inbuilt flat washer. Both the nuts and the lugs are available from Langs, but you won't like the price of the lugs.
Hope this helps.
Hope this helps.
- First Name: David
Finally found out how to upload picture of the rim I have that I need lugs for
