Wanted valve stems
Topic author - Posts: 1086
- First Name: Mike
- Last Name: Bird
Wanted valve stems
Looking for some valve stems for Model T. I have some original Schrader rim nuts and covers that I’m using. From what I have read on the forums there were other manufacturers other than Schrader that can be used in place of the 777. Anyone out there that has a set (4) that they would like to part with? Also would need bridge washers.
Mike Bird
mikebird@lifeattheridge.net or 574-584-6744
Mike Bird
- First Name: Mike
- Last Name: Bird
Re: Wanted valve stems
Bump back to top
- MTFCA Number: 121
- MTFCI Number: 16310
Dill, Bridgeport and Firestone also made them. All you need to do is find them. Schrader is the only company that used 777 for a part number. Most all of them use the TR designation, which stands for the Tire and Rim Association.
- First Name: Mike
- Last Name: Bird
Larry,
If I’m not mistaken the length of the stem does matter and the longest size you can use is 3” and the shortest is 2 3/4”?
- First Name: R.V.
- Last Name: Anderson
i believe the shortest are Schrader #888.
- First Name: Mike
- Last Name: Bird
So does anyone have any?
- First Name: Mike
- Last Name: Bird
Thanks for all the feedback guys...Got 1. Thanks Rich! Need 3 more. Anyone else?
- MTFCA Number: 121
Don't use anything longer than 2", unless you want to throw your wheels out of balance. Also, don't use modern ones. They are the wrong diameter.
- First Name: Mike
- Last Name: Bird
Larry, 2” or3”? I thought The 777 was 3”
- MTFCA Number: 121
The 777 is 3". Sorry. I like the 888 which is 2 3/4. It still works the same, and reduces the weight slightly.
- First Name: Mike
- Last Name: Bird
Thanks Larry,
I’m just checking here I didn’t know if you got my emails or not, but I’m guessing you don’t have anything that’ll work for me?
- First Name: Mike
- Last Name: Bird
Still looking. Anyone?
- First Name: Dale
- Last Name: Kemmerer
- * REQUIRED* Type and Year of Model Ts owned: 1909 touring 1911 open runabout
Mike, I have a couple of 825's but they are 3 1/2 inches long while the 777's & 888's are 3 inches.
- First Name: Mike
- Last Name: Bird
Dale,
Thanks but really looking for stems 2 3/4 to 3”
I have one Schrader 777 I also have 3 bridge washers and nuts. Just need 3 stems. Anyone? Dig deep through your coffee cans...
- MTFCA Number: 14972
- MTFCI Number: 15411
I dug out 2 888 & 1 Dill TR6 - identical to Schrader - it looks like - drop me a note, Mike.
- First Name: Mike
- Last Name: Bird
Thanks everyone who dug through their parts bins and found stuff they forgot they had. It looks like I got everything that I need now. Thanks again!
