Looking to trade a NOS Reeder aluminum H.C. head for H.C. high head
Topic author - Posts: 269
- First Name: Bruce
- Last Name: Compton
I have a NOS Reeder H.C. low head with new bolts and washers, the early version with the Ford script and "Made in USA" and would like to trade for a high H.C. head (Prus or Z type). The Reeder head was lightly installed on a rebuilt motor (not torqued down) and the buyer wanted a "stock" motor. I have a '26 Roadster that could use the H.C. High Head.
- Last Name: Williamson
Re: Looking to trade a NOS Reeder aluminum H.C. head for H.C. high head
Don't have H C head to trade, would be interested in buying your head
Richard Williamson
Richard Williamson
- First Name: Tom
- Last Name: Zimmer
- MTFCA Number: 15920
I have a Himico high compression high head. I can send pictures. I can either test them or email.
- First Name: Bruce
OK Tom, send an email. Bruce
- First Name: Tom
- Last Name: Zimmer
Need your email address
- First Name: Bruce
I am not sure why if you have the NOS Reeder head, you don't just use it?
1920 Dodge touring
1920 Dodge touring
- First Name: Bruce
Yes Mark, I'm thinking the same thing now. I assumed that the front water outlet would be lower and cause issues with the '26-27 fan belt adjustment but both outlets are the same distance from the gasket surface. The higher H.C. head would provide more coolant space, but I'll try it anyway.
Some of the after market heads already had more water capacity anyway, along with the fact you have a larger radiator being as it's a 27.
1920 Dodge touring
1920 Dodge touring
