This is a European style Robert Bosch magneto switch complete with removable key and wire cover, NOS New Old Stock, works perfectly.
1 3/4" diameter, works with any magneto that uses a grounded wire to kill the magneto ( Bosch DU4 ZR4 etc.). $225, domestic postage $12.
Bosch magneto switch NOS F/S
Topic author - Posts: 1509
- First Name: Layden
- Last Name: Butler
- Last Name: Butler
Re: Bosch magneto switch NOS F/S
To the top.
- Last Name: Butler
The ground wire clamp can go around the switch barrel and not use the sleeve cover.
Would consider trade on early Model T parts OR Model T speed equipment. What have you?
- Last Name: Butler
To the top
