FS Rear axle housing w/triple spring accessory shocks
Topic author - Posts: 143
- Last Name: Grisbee
- * REQUIRED* Type and Year of Model Ts owned: 0
I'm not sure if these are Hassler or something else. They appear to be in good condition with the exceptions of,the small top spring on the right end is broken and the bolt head below that shows some of the hole so there is wear in it. The housing is 16 or later so it's nothing special but not pitted or damaged from impact. In a perfect world someone close will pay $225 and pick it up. Otherwise it can be shipped or the units can be removed and shipped. Please contact me at the below email adderss if interested.
- MTFCA Number: 14972
- MTFCI Number: 15411
Re: FS Rear axle housing w/triple spring accessory shocks
Those are "Float-A-Ford" accessory shocks - nice !
I posted one pic of where there was the most wear but all the other points with those bolts are much better as pictured if that makes a difference with anyone. I suspect it'll be around until Chickasha next year. They are already advertising the 31st annual but if they didn't have a 30th,how does that figure?
