I reinstalled the Edison 14 spark plugs when I was restoring our 15 runabout. The car runs great with those plugs, but one of the electrodes was partially eaten away. I'd like to buy a NOS or "gently used" Edison 14 spark plug so that I can swap out the one plug.
Please send me a PM or email if you have a spare Edison 14 cluttering up your box of T parts that you would like to sell!
Thanks,
Neal
WTB Edison 14 spark plug
Re: WTB Edison 14 spark plug
I don't have any I want to sell, but if you are trying to match what you have? You should post a good photo or two, or a very good description including major dimensions, number of ribs (if any) near the top of the porcelain, and whether the base is "take-apart" or not.
I have had, and seen, a fair number of Edison plugs over the years (both 13s and 14s). They came in several variations. I have three 13s (dual electrode) that I wanted to use many years ago, but I never found a fourth that matched them! Since then, I decided they should take up space in my small display cabinet.
- Last Name: Strange
- MTFCA Number: 30944
- MTFCI Number: 23667
If you don't mind, please post a picture of the worn plug. Unless the electrodes are worn down to a nub, I would think that filing the electrode edges back to their original shape and regapping would make it work good as new.
Edison 14s do show up on Ebay occasionally, but you have to have to have a sharp eye - often one or two will be mixed in with a random bunch of plugs for sale, or it will be identified as an Edison, but the description won't spell out that it is a 14 or for a Model T.
Wayne, please check your email, I sent you an email via the forum.
Topic author - Posts: 398
- First Name: Neal
- Last Name: Willford
- * REQUIRED* Type and Year of Model Ts owned: 1911 Touring, 1915 Runabout
- MTFCA Number: 50256
I could probably file down the electrode a bit to square it off. I don't recall which plug it is, so with my luck I'd need to pull all four plugs to get to the correct one! Right now a corner is eroded off, and so I bumped the other electrode over a bit to get the desired gap. It seems to be working fine, but was hoping to find one with less wear and keep this as a spare. If no one has one, I'll just continue to watch ebay for oneIf you don't mind, please post a picture of the worn plug. Unless the electrodes are worn down to a nub, I would think that filing the electrode edges back to their original shape and regapping would make it work good as new.
