For Sale Model T Ford Generator Tester Drive Gear Adapter
Topic author - Posts: 533
- First Name: Ronald
- Last Name: Patterson
Building a Model T Ford generator tester? Using this device, you can directly spin your generator under test using the Ford generator drive gear. The shaft size is 5/8 inch with a hex head Allen screw to hold it to the motor shaft. You can directly spin the generator from the Model T generator drive gear instead of having to adapt the drive motor via belt or other non-standard drive methods. I had these manufactured several years ago when I was building a generator spin tester and have one left over. Price $50 plus Priority Mail shipping. Ron Patterson modeltcoils(at) windstream(dot)net.
Re: For Sale Model T Ford Generator Tester Drive Gear Adapter
email sent
NH Full Flow Float Valves
The drive gear adapter has been sold.
MTFCA
MTFCA
