Last call for 2020: FS - Full Flow Float Valves, valve install tool, and lead washer
Post by Scott_Conger » Fri Jul 10, 2020 8:58 pm
Full Flow Float Valves by itself... in stock: $25
Float valve install tool, limited quantity in stock, and only available with purchase of valve - add $40
And finally (no picture) a Lead washer to ENSURE no weeping past carb/valve interface, only available with purchase of valve. This replaces the hard red washer that so frequently fails to seal as expected - add $3
Postage for one, some or all: $8
Emails only please, no PM's. Also, I do not frequent this site as often as I used to, so a response here may be missed.
NH Full Flow Float Valves
Re: FS - Full Flow Float Valves, valve install tool, and lead washer
Post by Scott_Conger » Fri Jul 17, 2020 9:03 am
...and again...
rmalzo
First Name: Ray
Last Name: Malzo
Post by rmalzo » Fri Jul 17, 2020 12:40 pm
I have a model G Holley, do you float valves work on this carb? If so I would like to purchase the valve, the tool etc. Let me know, thank you
Last Name: Hatch
MTFCA Number: 49974
Post by Dan Hatch » Fri Jul 17, 2020 2:14 pm
Email sent. Dan
Also: if you ever work on an NH, you need this valve tool. Thanks Scott for making them, save me the trouble. Dan
Post by Scott_Conger » Sat Jul 25, 2020 10:01 am
..and again..
Post by Scott_Conger » Fri Jul 31, 2020 12:12 pm
Last call for 2020. Not going to keep pimping these things and annoying folks wanting to see their ads on top. The last of these will likely go to a couple of buyers who buy bulk, so if you thought you wanted one, now is the time.
Thanks for looking and have a safe time for the remainder of summer and into fall/winter.
