1926 Holley NH carburetor
Topic author - Posts: 592
- First Name: Corey
- Last Name: Walker
- MTFCA Number: 51502
New needle and seat, spray nozzle,drain assembly, choke spring,passages cleaned and sealed with set screws, tested float, test run. $165 postpaid to continental USA. Email: wlkma9@gmail.com
- First Name: Tom
- Last Name: Strickling
- * REQUIRED* Type and Year of Model Ts owned: 11 Torpedo, 18 Touring, 21 TT Huckster, 24 snowmpbile Staude and Shaw tractor conversions, Model T powered sickel bar mower
Re: 1926 Holley NH carburetor
Is it powder coated or painted? What kind if paint?
“The trouble with retirement is that you never get a day off.” – Abe Lemons.
- First Name: Corey
- Last Name: Walker
- First Name: Dallas
- Last Name: Landers
- MTFCA Number: 49995
Im running two carbs from Corey. They have both been in use for a couple years and havn't touched them since. My 26 RPU sat all week. I went out this morning pulled the throttle 1/3 open and pulled up on the crank one time and it was going. No priming, no choke. Very happy customer I am.
- First Name: Corey
- Last Name: Walker
- First Name: Terry
- Last Name: Woods
- MTFCI Number: 20180
Corey, I know that you have listed rebuilt NH carbs, previously, and one you said, had a special float to be used with a cowl mounted tank, if I'm not mistaken. I would be using this carb on a four door sedan with an under front seat mounted tank. Will this carb work for this body style and tank? If so, I'm a buyer.
- First Name: Corey
- Last Name: Walker
