WTB Running Board Step Plate
Topic author - Posts: 301
- First Name: Daniel
- Last Name: Snell
- MTFCA Number: 31662
- MTFCI Number: 23677
- Board Member Since: 2014
I would like to find a decent accessory step plate for my 25 roadster pick up. Just need one but would like original accessory item if possible. I hate to drill holes to mount it but have concluded it is the only way to keep big feet where they shouldn't be on a nice new paint job!
- First Name: Henry
- Last Name: Lee
- MTFCA Number: 479
Re: WTB Running Board Step Plate
Daniel are you looking for the aluminum ones with the Ford logo casted into them?
- Last Name: Snell
Hank, I would prefer to find an original rather than a reproduction. If the original has Ford on it all the better.
- First Name: Henry
- Last Name: Lee
- MTFCA Number: 479
I hear ya!
- First Name: Henry
- Last Name: Lee
- MTFCA Number: 479
Comments removed that I was referring to the scammer.
- Last Name: Snell
Won't be contacting her anytime soon!
- First Name: Ken
- Last Name: Buhler
- MTFCA Number: 49471
- Board Member Since: 2012
Daniel,
We have so many adhesives available now, we often don't need to drill holes. Research which adhesive would apply for your task. If you glue to a painted surface, the substrate must be secure by proper process. Auto body steel panels are being glued on in the repair process and hold structural integrity. I hope this helps. If anyone can share new info, please do.
- First Name: Bruce
- Last Name: Csorba
Daniel,
Another no drill choice.
I have a toolbox that attaches using the clamps off a rusty old expanding luggage rack.
Maybe a clamp on step?
Bruce Csorba
Melbourne, Australia
15 4-spring Rajo racer
17 C-cab van
25 "Dalgety" Tourer
17 C-cab van
25 "Dalgety" Tourer
- First Name: Janet
- Last Name: Block
- MTFCA Number: 32300
Bruce
If possible can u please post some photos of how you used clamps from a luggage rack to hold a toolbox to the running board ?
Janet
Janet
- First Name: Bruce
- Last Name: Csorba
Hey Janet, Another persons idea, I just bought it, but it matches the racer.
The brackets. The box with holes.
Hope this helps.
Bruce
Hope this helps.
Bruce
Bruce Csorba
17 C-cab van
25 "Dalgety" Tourer
17 C-cab van
25 "Dalgety" Tourer
Thoughts on gluing or clamping; If you glued it on, run the beads parallel to the running board so water or moisture can flow out. Once glued on would be more or less permanent so no taking if off if breaks or change your mind later without some work.
Clamps, depending on how thick/wide they are, most of the step plate would be unsupported so would flex every time it was stepped on which could lead to cracking or bowing. Most step plates I have seen are aluminum and not all that thick and were made to be mounted using the running boards as support under them.
If I were to suggest clamping, I would use a piece of plate that covered the most of or the whole area under the plate.
Just clamping it on, there is still going to be movement that will wear the paint and tops of the running board embossing every time it is stepped on or the running board flexes, which is what you are trying to avoid. You could attach a piece of thin rubber type material to the bottom of the plate. Using the clamps would allow you to remove and clean under it every so often.
1920 Dodge touring
1920 Dodge touring
- First Name: Eric
- Last Name: Keenan
Would magnets work, glue them onto the step plates. Use a piece of felt to protect the surface of the running board between the contact area.
- Last Name: Snell
Still looking for a plate, anyone
- First Name: Thomas
- Last Name: Quigley
This step plate us unused from what i can tell. It is solid brass. Asking $65 plus postage.
https://mtfca.com/phpBB3/download/file. ... w&id=60861
Hi David.
It is not brass plated. I do not believe has ever been on a car - no wear on the upper surface. I purchased a fellow's collection and it was among the items. Brass takes well to plating so i imagine you want it Nickle plated. No matter, here is the photo of the reverse side.
Thanks,
https://mtfca.com/phpBB3/download/file. ... w&id=60908
Thanks,
- Attachments
- step plate reverse.gif (43 Bytes) Viewed 1897 times
Send me your email address and we can communicate easier methinks. TQ
Daniel, sorry, i named you David. My mistake! TQ
- Last Name: Snell
- First Name: Janet
- Last Name: Block
Bruce
Thank you for posting photos of the luggage brackets used to hold the toolbox to the running board.
I am going to use your idea along with a thick piece of rubber between running board and toolbox to keep the toolbox from moving with the movement of the car.
I previously used a thick piece of rubber between running board and step plate and it makes it more stable when I step on it to get in and out of the car.
Janet
Janet
- First Name: Charles
- Last Name: Jenkins
- MTFCA Number: 28066
I have two different pairs could send you pictures charlesjenkins84@gmail.com
- Last Name: Snell
Charles,
Sent you an email.
Daniel
Sent you an email.
Daniel
