WTB Running Board Step Plate
SurveyKing
First Name: Daniel
Last Name: Snell
MTFCA Number: 31662
MTFCI Number: 23677
Board Member Since: 2014
Post by SurveyKing » Sun Jul 12, 2020 8:50 am
I would like to find a decent accessory step plate for my 25 roadster pick up. Just need one but would like original accessory item if possible. I hate to drill holes to mount it but have concluded it is the only way to keep big feet where they shouldn't be on a nice new paint job!
First Name: Henry
Last Name: Lee
MTFCA Number: 479
Re: WTB Running Board Step Plate
Post by Henry K. Lee » Sun Jul 12, 2020 9:00 am
Daniel are you looking for the aluminum ones with the Ford logo casted into them?
Hank
SurveyKing
First Name: Daniel
Last Name: Snell
MTFCA Number: 31662
MTFCI Number: 23677
Post by SurveyKing » Sun Jul 12, 2020 9:38 am
Hank, I would prefer to find an original rather than a reproduction. If the original has Ford on it all the better.
First Name: Henry
Last Name: Lee
MTFCA Number: 479
Post by Henry K. Lee » Sun Jul 12, 2020 10:24 am
I hear ya!
First Name: Henry
Last Name: Lee
MTFCA Number: 479
Post by Henry K. Lee » Sun Jul 12, 2020 3:55 pm
Comments removed that I was referring to the scammer.
SurveyKing
First Name: Daniel
Last Name: Snell
MTFCA Number: 31662
MTFCI Number: 23677
Post by SurveyKing » Sun Jul 12, 2020 5:22 pm
Won't be contacting her anytime soon!
Ken Buhler
First Name: Ken
Last Name: Buhler
MTFCA Number: 49471
Board Member Since: 2012
Post by Ken Buhler » Sun Jul 12, 2020 9:24 pm
Daniel,
We have so many adhesives available now, we often don't need to drill holes. Research which adhesive would apply for your task. If you glue to a painted surface, the substrate must be secure by proper process. Auto body steel panels are being glued on in the repair process and hold structural integrity. I hope this helps. If anyone can share new info, please do.
doodlebugt
First Name: Bruce
Last Name: Csorba
Post by doodlebugt » Sun Jul 12, 2020 10:37 pm
Daniel,
Another no drill choice.
I have a toolbox that attaches using the clamps off a rusty old expanding luggage rack.
Maybe a clamp on step?
Bruce Csorba
Melbourne, Australia
15 4-spring Rajo racer
17 C-cab van
25 "Dalgety" Tourer
Janet_Block
First Name: Janet
Last Name: Block
MTFCA Number: 32300
Post by Janet_Block » Tue Jul 14, 2020 9:43 pm
Bruce
If possible can u please post some photos of how you used clamps from a luggage rack to hold a toolbox to the running board ?
Janet
doodlebugt
First Name: Bruce
Last Name: Csorba
Post by doodlebugt » Wed Jul 15, 2020 6:23 am
Hey Janet, Another persons idea, I just bought it, but it matches the racer.
The brackets.
Rack brackets
Rack brackets
The box with holes.
Hope this helps.
Bruce
Tool box
Tool box
Bruce Csorba
17 C-cab van
25 "Dalgety" Tourer
Post by Mark Gregush » Wed Jul 15, 2020 10:42 am
Thoughts on gluing or clamping; If you glued it on, run the beads parallel to the running board so water or moisture can flow out. Once glued on would be more or less permanent so no taking if off if breaks or change your mind later without some work.
Clamps, depending on how thick/wide they are, most of the step plate would be unsupported so would flex every time it was stepped on which could lead to cracking or bowing. Most step plates I have seen are aluminum and not all that thick and were made to be mounted using the running boards as support under them.
If I were to suggest clamping, I would use a piece of plate that covered the most of or the whole area under the plate.
Just clamping it on, there is still going to be movement that will wear the paint and tops of the running board embossing every time it is stepped on or the running board flexes, which is what you are trying to avoid. You could attach a piece of thin rubber type material to the bottom of the plate. Using the clamps would allow you to remove and clean under it every so often.
1920 Dodge touring
keen25
First Name: Eric
Last Name: Keenan
Post by keen25 » Wed Jul 15, 2020 11:41 am
Would magnets work, glue them onto the step plates. Use a piece of felt to protect the surface of the running board between the contact area.
SurveyKing
First Name: Daniel
Last Name: Snell
MTFCA Number: 31662
MTFCI Number: 23677
Post by SurveyKing » Wed Jul 15, 2020 12:15 pm
Still looking for a plate, anyone
Tom Quigley
First Name: Thomas
Last Name: Quigley
Post by Tom Quigley » Sat Jul 18, 2020 9:09 am
This step plate us unused from what i can tell. It is solid brass. Asking $65 plus postage.
https://mtfca.com/phpBB3/download/file. ... w&id=60861
Tom Quigley
First Name: Thomas
Last Name: Quigley
Post by Tom Quigley » Sat Jul 18, 2020 5:59 pm
Hi David.
It is not brass plated. I do not believe has ever been on a car - no wear on the upper surface. I purchased a fellow's collection and it was among the items. Brass takes well to plating so i imagine you want it Nickle plated. No matter, here is the photo of the reverse side.
Thanks,
https://mtfca.com/phpBB3/download/file. ... w&id=60908
step plate reverse.gif (43 Bytes) Viewed 1896 times
Tom Quigley
First Name: Thomas
Last Name: Quigley
Post by Tom Quigley » Sat Jul 18, 2020 6:00 pm
Send me your email address and we can communicate easier methinks. TQ
Tom Quigley
First Name: Thomas
Last Name: Quigley
Post by Tom Quigley » Sat Jul 18, 2020 6:04 pm
Daniel, sorry, i named you David. My mistake! TQ
SurveyKing
First Name: Daniel
Last Name: Snell
MTFCA Number: 31662
MTFCI Number: 23677
Post by SurveyKing » Sat Jul 18, 2020 6:27 pm
Hi Tom, please feel free to email me at:
DanielSnell2@twc.com
Janet_Block
First Name: Janet
Last Name: Block
MTFCA Number: 32300
Post by Janet_Block » Sun Jul 19, 2020 10:58 pm
Bruce
Thank you for posting photos of the luggage brackets used to hold the toolbox to the running board.
I am going to use your idea along with a thick piece of rubber between running board and toolbox to keep the toolbox from moving with the movement of the car.
I previously used a thick piece of rubber between running board and step plate and it makes it more stable when I step on it to get in and out of the car.
Janet
Charles J
First Name: Charles
Last Name: Jenkins
MTFCA Number: 28066
Post by Charles J » Sun Jul 19, 2020 11:14 pm
I have two different pairs could send you pictures charlesjenkins84@gmail.com
SurveyKing
First Name: Daniel
Last Name: Snell
MTFCA Number: 31662
MTFCI Number: 23677
Post by SurveyKing » Mon Jul 20, 2020 11:26 am
Charles,
Sent you an email.
Daniel
