No Longer Available
Chad_Marcheese
First Name: Chad
Last Name: Marcheese
MTFCA Number: 26904
No Longer Available
Post by Chad_Marcheese » Fri Jul 17, 2020 9:34 pm
No Longer Available
Last edited by Chad_Marcheese on Thu Aug 13, 2020 8:47 pm, edited 2 times in total.
Chad_Marcheese
First Name: Chad
MTFCA Number: 26904
Re: Spindles with straight steering arms
No Longer Available
Last edited by Chad_Marcheese on Thu Aug 13, 2020 8:47 pm, edited 1 time in total.
David Mazza
First Name: David
Last Name: Mazza
Post by David Mazza » Fri Jul 17, 2020 10:38 pm
The arms are the early style with the speedometer mount hole.
Ken Buhler
First Name: Ken
Last Name: Buhler
MTFCA Number: 49471
Board Member Since: 2012
Post by Ken Buhler » Sat Jul 18, 2020 12:37 am
Chad, you do not want to be using the one with the notch. That is from a washer that got loose and cut a groove.
Post by Allan » Sat Jul 18, 2020 3:49 am
Chad, the spindle with the wear grove is the later type with the flats on the shoulder so the bearing can be driven off, so it is no great loss.
Chad_Marcheese
First Name: Chad
MTFCA Number: 26904
Post by Chad_Marcheese » Sat Jul 18, 2020 6:55 am
Thanks gentleman. I do realize the grooved spindle is not what I would use personally. As mentioned in my ad, the arms are the real value here.
If someone just wants the arms, I will remove them. Just trying to clear out some parts that are around here.
