WTB Leaf Spring
Topic author - Posts: 449
- First Name: Daniel
- Last Name: Snell
- * REQUIRED* Type and Year of Model Ts owned: 1909 Touring, 1924 Touring, 1925 Roadster Pickup, 1921 Touring
- MTFCA Number: 31662
- MTFCI Number: 23677
- Board Member Since: 2014
WTB Leaf Spring
I am in need of the seventh or smallest leaf of the front tapered leaf spring. Also need the front spring clips for the curled eye spring that is held by a rivet. Please email me at DanielSnell2@twc.com
- First Name: Henry
- Last Name: Lee
- MTFCA Number: 479
Re: WTB Leaf Spring
Can you give me the length? Have some loose ones.
- Last Name: Snell
Re: WTB Leaf Spring
It looks to be about 10 inches long more or less. The sixth leave is 14 inches so is smaller than that by approx 4 inches.
- First Name: Henry
- Last Name: Lee
- MTFCA Number: 479
Re: WTB Leaf Spring
I have a 12 1/4” and a 16 1/2”.
- Last Name: Snell
Re: WTB Leaf Spring
Hi Hank,
I am trying to put together an additional early set. The leaves I have on my 1909 measures (as best as I can while on the car) is as follows:
1st leaf = 33 1/4
2nd leaf = 31 1/2
3rd leaf = 28 1/4
4th (curled eye) = 25 1/4
5th leaf = 21 1/4
6th leaf = 16 3/4
7th leaf = 12 1/2
My additional set that I am trying to put together has the first four leaves pretty much the same, but the 5th is 19 1/2 and the 6th is 14 1/4 that could have come off of another non-ford car, so I am now thinking I need the 5th, 6th and 7th leaves, which should measure close to what I have listed above. You mentioned you have 12 1/4 and 16 1/2 so those I need, but also need the 5th leaf at 21 1/4. Do you also have that one? If so, I'd like to get all three from you.
1st leaf = 33 1/4
2nd leaf = 31 1/2
3rd leaf = 28 1/4
5th leaf = 21 1/4
6th leaf = 16 3/4
7th leaf = 12 1/2
- First Name: Henry
- Last Name: Lee
- MTFCA Number: 479
Re: WTB Leaf Spring
I have an 18 1/2” and a 24 1/2” but not those others.
- First Name: Henry
- Last Name: Lee
- MTFCA Number: 479
Re: WTB Leaf Spring
18 and 23” in a straight line.
- Last Name: Snell
Re: WTB Leaf Spring
Back to the top still looking for seventh or smallest front spring leaf and curled eye spring clips which are held by a rivet. Thanks
