FS- Early 1913 Engine - Rebuilt
skeiss
First Name: Stephen
Last Name: Keiss
MTFCA Number: 31895
Post by skeiss » Sun Feb 17, 2019 11:05 am
For Sale
Strong running and driving early 1913 powerplant with good quality older rebuild. Currently set up with later electric start. Engine starts and runs well on magneto. Low head, aluminum pistons, tight babbit / bearings, later straight throw crankshaft, drums / bands transmission in great condition. Has slightly newer bronze body Holley G carb., Currently sitting in a later (20's) frame. Has newer hogs head / pedals and three dip pan. Have flushed cooling system, but would hurt to do again.
Can yard driven / jacked up and run.
The powerplant was rebuilt for a depot hack project that never progressed beyond the engine rebuild frame stage. No title.
If desired, the frame is included (less tubes/tires, demountabe rims and gas tank).
VIN #: 186901
Cast date: 10-27-1912
Asking $4500.00 OBO. Local pickup only from Wellington Colorado, 80549
Thank you,
Steve
capewake
First Name: David
Last Name: Herring
MTFCA Number: 22001
MTFCI Number: 24521
Re: FS- Early 1913 Engine - Rebuilt
Post by capewake » Sun Feb 17, 2019 2:16 pm
Hi Stephen
PM sent
SurfCityGene
First Name: Gene
Last Name: Carrothers
MTFCA Number: 22905
MTFCI Number: 23068
Post by SurfCityGene » Fri Feb 22, 2019 6:31 pm
Do you know what the bore size Is? valves replaced? Did you mean you can drive it in the yard?
Gene
1912 Torpedo Roadster
HornsRus
First Name: Charley
Last Name: Shaver
Post by HornsRus » Sat Feb 23, 2019 5:00 pm
could we see a pic of back of the block above the mag post.thanks charley
Russ_Furstnow
First Name: Russ
Last Name: Furstnow
MTFCA Number: 28
MTFCI Number: 10546
Post by Russ_Furstnow » Sat Feb 23, 2019 7:14 pm
Charley, The length of the raised portion where the serial number is stamped was changed to the length shown in the photo in late 1916 when the numbers were seven digits long. The 1915 engine in my coupelet has a much shorter raised portion. There are other items that indicate this may be a later block.
I hope this helps.
Russ Furstnow
Joe Bell
First Name: Joe
Last Name: Bell
MTFCI Number: 24066
Post by Joe Bell » Sat Feb 23, 2019 8:01 pm
Should have a number on the right side of block below the valve cover, I have seen 1-5 there, Good eye Russ!
HornsRus
First Name: Charley
Last Name: Shaver
Post by HornsRus » Sat Feb 23, 2019 8:40 pm
i really didn't want to say anything!!!! charley
skeiss
First Name: Stephen
Last Name: Keiss
MTFCA Number: 31895
Post by skeiss » Sun Feb 24, 2019 10:39 am
I have included a photo of the back of the block for review. I would like to verify the year of the block as I was going from the engine number and casting date.
In response to the question on piston size, I have not pulled the head and don't know if the pistons are oversize.
Thank you.
Michael Paul
First Name: Michael
Last Name: Paul
MTFCA Number: 31791
Post by Michael Paul » Sun Feb 24, 2019 11:08 am
Sure looks like a later block with a #2 welded or patched in at the end of the casting date. Notice the raised portion stops at #1. As Charly pointed out there is no lip at the end of the block above the magneto post.
Still looks like a nice chassis for the price.
Russ_Furstnow
First Name: Russ
Last Name: Furstnow
MTFCA Number: 28
MTFCI Number: 10546
Post by Russ_Furstnow » Sun Feb 24, 2019 11:19 am
The water jacket at the rear of the block indicates it is a later block. Early 1913 and late 1912 blocks had a "lip" where the block meets the head at the water jacket. I would check the "2" on the "12" casting date to see if it is a "faux" number (just scrape it a little). From what I see, the block is probably a 1916-1918 block.
I hope this helps,
Russ Furstnow
Russ_Furstnow
First Name: Russ
Last Name: Furstnow
MTFCA Number: 28
MTFCI Number: 10546
Post by Russ_Furstnow » Sun Feb 24, 2019 11:21 am
BTW, the engine pan is also a later pan, not a "needle nose" pan.
brassford
First Name: Rick
Last Name: Epstein
MTFCA Number: 30326
Post by brassford » Sun Mar 24, 2019 1:38 pm
Is the engine still available?
