Virtual swap meet-goodies for sale
Topic author - Posts: 1098
- First Name: Mike
- Last Name: Bird
Want to haggle on price? Sure can! Let's make a deal! Shipping not included
Mike Bird 574-584-6744 or mikebird@lifeattheridge.net
Rear Fender Brackets- $15
Prestolite B Tank brackets-SOLD
Early crank arm- SOLD
DB B Pedal (have weld on B pedal head I'll throw in)-$40
Weld on R pedal head-$5
Good set of rear axle gears- SOLD
Tie rod bolts-$5
2302 Stewart Speedo Fiber drive gear-$5
Early hood hooks-$20
Brass door handles (not T) could be used on a non ford commercial body, depot hack etc.-$20
Set of 777 Schrader valve stems with bridge washers, nuts, Hex rim nuts and only 1 Schrader stem cover- SOLD
- Last Name: Clements
- MTFCA Number: 49592
Re: Virtual swap meet-goodies for sale
I will take the valve stems and the axle gears.
- First Name: Mike
- Last Name: Bird
Valve Stems and Axle Gears Sold to Scott- Thanks MTFCA
- MTFCA Number: 52564
I'll take the speedo gear. Email sent
1920 Dodge touring
1920 Dodge touring
- First Name: Layden
- Last Name: Butler
I'll take the Prest-O-Lite thank brackets (3).
- First Name: Mike
- Last Name: Bird
Tbird wrote: ↑Mon Aug 03, 2020 11:13 am1.JPG
See something you like? I can send some more pictures on request.
Early crank arm- $15
Tie rod bolts-$5
2302 Stewart Speedo Fiber drive gear-SOLD
- First Name: Mike
- Last Name: Bird
Stewart Fiber Gear and Prestolite Brackets Sold
Thanks MTFCA
Thanks MTFCA
- First Name: Mike
- Last Name: Bird
Early crank arm Sold
Thanks MTFCA
Thanks MTFCA
