Virtual swap meet-goodies for sale
Tbird
Last Name: Bird
Post by Tbird » Mon Aug 03, 2020 11:13 am
See something you like? I can send some more pictures on request.
Want to haggle on price? Sure can! Let's make a deal! Shipping not included
Mike Bird 574-584-6744 or mikebird@lifeattheridge.net
Rear Fender Brackets- $15
Prestolite B Tank brackets-SOLD
Early crank arm- SOLD
DB B Pedal (have weld on B pedal head I'll throw in)-$40
Weld on R pedal head-$5
Good set of rear axle gears- SOLD
Tie rod bolts-$5
2302 Stewart Speedo Fiber drive gear-$5
Early hood hooks-$20
Brass door handles (not T) could be used on a non ford commercial body, depot hack etc.-$20
Set of 777 Schrader valve stems with bridge washers, nuts, Hex rim nuts and only 1 Schrader stem cover- SOLD
Scott C.
Last Name: Clements
MTFCA Number: 49592
Re: Virtual swap meet-goodies for sale
Post by Scott C. » Mon Aug 03, 2020 11:31 am
I will take the valve stems and the axle gears.
Tbird
Last Name: Bird
Post by Tbird » Mon Aug 03, 2020 11:38 am
Valve Stems and Axle Gears Sold to Scott- Thanks MTFCA
* REQUIRED* Type and Year of Model Ts owned: 1925 cutdown PU, 1920 Dodge touring, 1948 F2 Ford flat head 6 pickup 3 speed
MTFCA Number: 52564
Post by Mark Gregush » Mon Aug 03, 2020 11:46 am
I'll take the speedo gear. Email sent
1920 Dodge touring
Layden Butler
First Name: Layden
Last Name: Butler
Post by Layden Butler » Mon Aug 03, 2020 11:49 am
I'll take the Prest-O-Lite thank brackets (3).
Tbird
Last Name: Bird
Post by Tbird » Mon Aug 03, 2020 11:52 am
Early crank arm- $15
Tie rod bolts-$5
2302 Stewart Speedo Fiber drive gear-SOLD
Tbird
Last Name: Bird
Post by Tbird » Mon Aug 03, 2020 11:54 am
Stewart Fiber Gear and Prestolite Brackets Sold
Thanks MTFCA
Tbird
Last Name: Bird
Post by Tbird » Mon Aug 03, 2020 12:56 pm
Early crank arm Sold
Thanks MTFCA
