WTB a fonctional used Magneto
Topic author - Posts: 1198
- First Name: Mario
- Last Name: Brossard
- MTFCA Number: 30981
- MTFCI Number: 30981
Hi, I’m looking for a good fonctional used magneto to go with my 1926 transmission and engine.I do not need the magnet or the flywheel, just missing the Magneto.
I would like to have an engine stand to try different carbs and adjust them.
Thank you MTFCA.
Thank you MTFCA.
Super Mario Bross
1911 Touring
1914 Speedster
1911 Touring
1914 Speedster
- Last Name: Rogers
- Board Member Since: 2013
Re: WTB a fonctional used Magneto
Mario, your request does not make sense. Below is a Model T magneto assembly:
- MTFCA Number: 28924
Think he means the field coil.
- First Name: Mario
Yes correct the field coil thx
Super Mario Bross
1911 Touring
1914 Speedster
1911 Touring
1914 Speedster
- First Name: Adam
- Last Name: Doleshal
- MTFCA Number: 23809
- MTFCI Number: 1
I have 2, 4 foot high stacks of used field coils. Probably about 100 of them. I can guarantee that EVERY one of them is a gamble, even if tested. There is probably a 50/50 chance that any one of them may or may not last a couple years. Why chance a failure and disassembly, replacement, reassembly when a good rebuilt field coil is around $200? Removal of engine, removal and replacement of field coil, reassembly, and replacement of engine is about 17 hours, not including gaskets, shims, sealer, and “whatever else”...
- * REQUIRED* Type and Year of Model Ts owned: 1925 cutdown PU, 1920 Dodge touring, 1948 F2 Ford flat head 6 pickup 3 speed
- MTFCA Number: 52564
He is just building a test engine, not for a car. It's going on a test stand.
1920 Dodge touring
1920 Dodge touring
- First Name: Mario
Hi Mark is correct, I'm just building a test engine, not for a car... I already have a used field coil but it is in miserable condition. If I want to run on magneto it will not work at all. I would like to test also coil boxe for our local chapter.
Still looking. Thank you MTFCA members
Super Mario Bross
1911 Touring
1914 Speedster
1911 Touring
1914 Speedster
- First Name: R.V.
- Last Name: Anderson
I think I can help you. I have a rewound field coil that was sent to me about 12 years ago in exchange for a new one, though there was/is nothing wrong with the one he sent. It's not my work but it works fine; has been sitting on the shelf ever since. I'll get it down and clean it up; amazing how much dust gathers on a shelf in a mere 1-1/5 decades.
