OT Dodge Brothers 1920 gas cap needed
MTFCA Number: 52564
Post by Mark Gregush » Fri Aug 07, 2020 8:27 pm
Any one have a Dodge Brothers gas cap that would fit a 1920 kicking around? The threads on the tank are about 2-1/2 inches and 13 TPI. The top is 6 sided on a larger round base. (as I recall) Or even just a cap that would fit would work,.
1920 Dodge touring
NevinG
First Name: Nevin
Last Name: Gough
* REQUIRED* Type and Year of Model Ts owned: 1918 Light Delivery
Re: OT Dodge Brothers 1920 gas cap needed
Post by NevinG » Mon Aug 10, 2020 1:52 am
Who would have a DB, and be on a MTFCA site?? : )
Post by Wayne Sheldon » Mon Aug 10, 2020 4:56 am
David Dewey, Gene French, and about six others I know of?
MTFCA Number: 52564
Post by Mark Gregush » Mon Aug 10, 2020 10:16 am
Don't forget most everyone that has a T built before 1914, well at least in part. :)
1920 Dodge touring
Gene_French
First Name: Gene
Last Name: French
MTFCA Number: 15614
Board Member Since: 2014
Post by Gene_French » Mon Aug 10, 2020 4:49 pm
Mark:
i will look around in my DB parts ... i am sure i have a cap IF i can find it ... am currently adding on my shop building and have stuff piled on top of piles of stuff ... too much stuff ! always an optimist ...Gene French
MTFCA Number: 52564
Post by Mark Gregush » Mon Aug 10, 2020 6:40 pm
Great and thank you Gene. :)
1920 Dodge touring
david_dewey
First Name: David
Last Name: Dewey
MTFCI Number: 19936
Post by david_dewey » Mon Aug 10, 2020 10:01 pm
Glad Gene probably has one, I couldn't tell you where my DB gas tank stuff is right now. However, I do see them on eBay frequently. They don't seem to be uncommon like some DB parts are!
And Wayne was right! :)
T'ake care,
David Dewey
MTFCA Number: 52564
Post by Mark Gregush » Mon Aug 10, 2020 10:25 pm
I have been watching eBay, even using different search parameters, so far no go. I checked with Myers Early Dodge, LOL I am use to T parts prices and expect higher for Dodge and Chevrolet so when they gave me a price of 45 plus shipping for a used cap, time to do more looking. :)
1920 Dodge touring
Thorlick
First Name: Terry
Last Name: Horlick
* REQUIRED* Type and Year of Model Ts owned: 1927 Roadster Pickup "Mountain Patrol vehicle" from Los Angeles City Fire Department and a 1912 Model T omnibus restoration project
MTFCA Number: 50510
Post by Thorlick » Sat Sep 19, 2020 11:49 am
Erik Barrett took his Dodge Brothers on a tour I was on about ten years ago.
david_dewey
First Name: David
Last Name: Dewey
MTFCI Number: 19936
Post by david_dewey » Sat Sep 19, 2020 5:17 pm
I drove Erik's DB on a tour two years ago, took his Dad along, likely one of his last tours. Had a great time! But wish the DB brakes were a little better. Will have to see what I can do to mine when I get it back together. (after the Ts!) :)
Mark, did you find a cap yet?
T'ake care,
David Dewey
MTFCA Number: 52564
Post by Mark Gregush » Sat Sep 19, 2020 6:30 pm
Not yet. Have and ad on AACA but no luck so far. glad your ok. I am going to check a wrecking yard down in Springfield next week and see what they might have.
1920 Dodge touring
D Stroud
First Name: David
Last Name: Stroud
Board Member Since: 2011
Post by D Stroud » Sun Sep 20, 2020 3:33 am
Mark, quick question. Are the threads the same as a T tank? In other words, would a T cap fit the Dodge? My '25 coupe has a cast iron cap that sounds similar to what you need, I have no idea where it came from. Dave
1925 mostly original coupe.
MTFCA Number: 52564
Post by Mark Gregush » Sun Sep 20, 2020 9:46 am
No, the threads are external on the neck (male), internal (female) on the cap. Thanks for checking.
1920 Dodge touring
Post by TRDxB2 » Sun Sep 20, 2020 11:56 am
Saw this on eBay. sort of matches your description: female threads and appears to be six sided. https://www.ebay.com/itm/Antique-Boyce- ... Sw31pfZ0-i
david_dewey
First Name: David
Last Name: Dewey
MTFCI Number: 19936
Post by david_dewey » Sun Sep 20, 2020 3:20 pm
Sorry Frank, that's a radiator cap. The cap Mark is looking for has a long "tit" on it, fairly unique piece that I've not seen on any other cars. here's a rough sketch of one from memory;
T'ake care,
David Dewey
Last Name: Strange
MTFCA Number: 30944
MTFCI Number: 23667
Post by CudaMan » Sun Sep 20, 2020 4:18 pm
MTFCA Number: 52564
Post by Mark Gregush » Sun Sep 20, 2020 4:34 pm
I think the one shown on the aaca thread is earlier. As far as I know that style would work, but think Dodge got rid of the tower and added a splash shield on the inside, like some of the T gas caps. Other wise the shape is the same as posted in the link. If I don't find one soon, am going to solder the neck off a Model A gas tank on. Would be easy to remove later and gas caps are a plenty. :)
1920 Dodge touring
