FS Rebuilt Model T Transmissions
First Name: Henry
Last Name: Lee
MTFCA Number: 479
Post by Henry K. Lee » Fri Aug 07, 2020 8:47 pm
In various forms of rebuilding, from stock to serious upgrades
Small drum, non electric with magnets, all steel clutch disc, all new bushings and pins, balanced triple gears, drums crack checked and resurfaced, Kevlar bands, stock Babbitt forth main..., $750.00
All listed below have balanced flywheels,
Small drum, electric with new starter ring gear(no magnets), Jack Rabbit clutches, all new bushings and pins, drums crack checked and resurfaced, balanced triple gears, Kevlar bands with removable ears, machined tail shaft with ball bearing forth main....., $1,000.00
Small drum, electric with new starter ring gear(no magnets), Jack Rabbit clutches, all new bushings and pins, drums crack checked and resurfaced with new brake drum, balanced triple gears, Kevlar bands with removable ears, machined tail shaft with ball bearing forth main...., $1,450.00
Large drum, electric with new starter ring gear(no magnets), Jack Rabbit clutched, all new bushings and pins, drums crack checked and resurfaced, balanced triple gears, Kevlar bands with removable ears, machined tail shaft with ball bearing forth main....., $1,200.00
Large drum, electric with new starter ring gear(no magnets), Jack Rabbit clutches, all new bushings and pins, drums crack checked resurfaced with new brake drum, balanced triple gears, Kevlar bands with removable ears, machined tail shaft with ball bearing forth main....$1,500.00
Email Only. Shipping is extra, would prefer pick up. Clean magnets and attachment hardware will be supplied but will require recharging for free (limited supply).
All the Best,
First Name: Henry
Last Name: Lee
MTFCA Number: 479
Re: FS Rebuilt Model T Transmissions
Post by Henry K. Lee » Sun Aug 16, 2020 3:36 pm
Small drum for $1,450.00 Sold, Thanks MTFCA!
First Name: Henry
Last Name: Lee
MTFCA Number: 479
Post by Henry K. Lee » Thu Oct 29, 2020 4:18 pm
XXXXXXXXXX
First Name: DAVID
Last Name: HJORTNAES
MTFCA Number: 28762
MTFCI Number: 22402
Post by DHort » Thu Oct 29, 2020 11:05 pm
Are your boys back in school or are schools closed like they are up here?
First Name: Henry
Last Name: Lee
MTFCA Number: 479
Post by Henry K. Lee » Fri Oct 30, 2020 7:54 am
David,
One is doing great, doing the ZOOM thing, helping me after school and the other I had to let go due to lying and deception with failing grades. It's all good, they were briefed on the the golden rules to follow. Thanks for asking.
Sean Butler
First Name: Sean
Last Name: Butler
MTFCA Number: 31557
Post by Sean Butler » Fri Oct 30, 2020 4:28 pm
Wow! Good on you, Hank. Set a standard and hold to it. We need a lot more of that out there. May be one of the best lessons he leans.
With respect, Sean.
Sean Butler
Huntington Beach, CA
