Wanted: Perry Auto Lock PA 129 key.
Topic author - Posts: 563
- First Name: Ignacio
- Last Name: Valdes
- MTFCA Number: 50406
I have Perry Auto Lock that has no key on it. The lock says Yale and PA 129 stamped on it. I am looking for a key for it. MTFCA discussion and pictures of what these are is here: http://www.mtfca.com/discus/messages/25 ... 1333215460
- First Name: Hap
- Last Name: Tucker
- MTFCA Number: 100
Re: Wanted: Perry Auto Lock PA 129 key.
Ignacio,
It looks like it uses a standard "Yale" key. And from your photo is looks like they broke a key off in the lock cylinder -- although that may just be dirt?
If you locate a real lock smith (there are fewer and fewer of them), they can usually salvage the lock cylinder and make you a key. I had one made for my original 1931 locking door handle back around 1982 or so and I had one made for my accessory coil box lock on my 1918 "Donor" T [bummer of a name for a car....] back in 2000 or so. In both cases they gave no guarantee they could do it, but said they would try. And both times they were able to salvage the lock cylinder (they had both been stored in dry inside storage). The first key was expensive ($25 or $35 dollars back then -- you could purchase a complete replacement Model A locking door handle for around the same amount). But the next 3 additional keys were a $1.50 each or something very reasonable.
Is there something stuck in your the lock cylinder?
Good luck with your project.
Respectfully submitted,
Hap l9l5 cut off
Hap l9l5 cut off
- Last Name: Valdes
I thought it was a busted key too but it was just some crud. That's what I was thinking too getting an old school locksmith if I can find one. If someone has a clear picture of what the key might have looked like that would help. I've seen some ambiguous pictures.
- First Name: Henry
- Last Name: Lee
- MTFCA Number: 479
Look on Tbay, I have had good luck there.
- First Name: Darel
- Last Name: Leipold
- MTFCA Number: 823
- MTFCI Number: 953
An locksmith can use a code book to cut a key. I have a code book and l will look up tomorrow.
- Last Name: Valdes
So far this is a bust. I took it to a local locksmith. Ater a month they gave up on it saying they could not find a key blank for it and had thrown away their antique code books. They also could not pick it. I did clean out the key way and oil it they probably did too but so far nothing. The locksmith said even a picture of a proper key would be helpful. They said they could drill it if they had to but I don't want to destroy it yet. If anyone has anything advise or a picture of the proper key for this it would be greatly appreciated.
- First Name: Darel
- MTFCA Number: 823
- MTFCI Number: 953
The yale key is marked "security". I could not find it listed in my old code book. The blank probably is very hard to find at this time.
- First Name: Terry
- Last Name: Woods
- MTFCI Number: 20180
Ignacicio, The first thing that needs to be done is to thoroughly clean the lock cylinder. From a locksmith's point of view, I don't know whether they would prefer to do it, or whether they would want the owner to do it. They might have a particular way that they prefer. After its clean, a good locksmith may be able to "impession" the cut of the original key, without removing the lock cylinder, or he may have to remove the cylinder from the auto lock. Either way a good locksmith should be able to help. The only lock I have ever had (and there have been a few) that I haven't been able to have repaired was an original Briggs & Stratton door lock cylinder for my 27 T, because it was made of pot metal and had swollen. Try the last locksmith that I used in Rosenburg. I'll post his name and number when I find it.
- First Name: Darel
- MTFCA Number: 823
- MTFCI Number: 953
/Users/darelleipold/Desktop/yale perry lock key.jpg
- Last Name: Valdes
Thanks, I have been directed to https://www.lostakey.net/ and that it is a '1000 key for Yale and Towne Vintage padlocks and Yale Series 8' so here goes...
- First Name: Terry
- Last Name: Woods
Ignacio, as I emailed you, there are more than one possible blank. The number 1000 Yale blank is just one of several possibilities. Hopefully Josh at lostakey can determine which one that you need from your key cut number.
- Last Name: Valdes
Unfortunately lostakey gave up because the PA key blank is discontinued.
