Wanted tail light mount
Divcoone
Last Name: Giles
* REQUIRED* Type and Year of Model Ts owned: Speedster
MTFCA Number: 25039
Post by Divcoone » Tue Aug 25, 2020 5:52 pm
I think these were used on Depo Hacks.
Bob Giles
divco100b@icloud.com
Joe Bell
First Name: Joe
Last Name: Bell
MTFCI Number: 24066
Re: Wanted tail light mount
Post by Joe Bell » Tue Aug 25, 2020 5:54 pm
Bob, I think I have one bu tit has the license plate mount bolted to the other hole.
Divcoone
Last Name: Giles
MTFCA Number: 25039
Post by Divcoone » Tue Aug 25, 2020 6:33 pm
Joe, I’m not using the license plate mounting hole. I want to mount one on the right side.
Erik Johnson
First Name: Erik
Last Name: Johnson
Post by Erik Johnson » Tue Aug 25, 2020 9:26 pm
What you have pictured is a 1915 touring tail lamp bracket. It's missing the license plate holder/bracket.
The license plate holder bolts onto it via a threaded prong that goes through the hole and it is held in place with a castle nut.
The 1916 touring bracket is also a two-piece bracket except the license plate holder is riveted on.
Google the forum and you will see some examples.
FordFool
First Name: Don
Last Name: Kirtley
* REQUIRED* Type and Year of Model Ts owned: 13 and 16 touring, 18 and 20 coup, 20 tudor
MTFCA Number: 23703
MTFCI Number: 23153
Board Member Since: 2009
Post by FordFool » Wed Aug 26, 2020 2:57 pm
Just cut the license plate bracket off the touring holder. That’s what I did. They are plentiful. Don
Divcoone
Last Name: Giles
MTFCA Number: 25039
Post by Divcoone » Wed Aug 26, 2020 4:16 pm
More details. I’ll use the one I have on the left minus the plate holder. I’m looking for another one to use on the right minus the plate holder. It’s for a Speedster.
Joe Bell
First Name: Joe
Last Name: Bell
MTFCI Number: 24066
Post by Joe Bell » Wed Aug 26, 2020 5:29 pm
Bob, there is a couple around on the shelf will try to look tomorrow.
Jack Putnam, in Ohio
First Name: Jack
Last Name: Putnam
MTFCA Number: 13833
MTFCI Number: 13353
Post by Jack Putnam, in Ohio » Thu Aug 27, 2020 1:29 pm
I have them. I reproduce the 15 bracket.
