Wanted tail light mount
- First Name: Joe
- Last Name: Bell
- MTFCI Number: 24066
Re: Wanted tail light mount
Bob, I think I have one bu tit has the license plate mount bolted to the other hole.
Topic author - Posts: 187
- Last Name: Giles
- * REQUIRED* Type and Year of Model Ts owned: Speedster
- MTFCA Number: 25039
Joe, I’m not using the license plate mounting hole. I want to mount one on the right side.
- First Name: Erik
- Last Name: Johnson
What you have pictured is a 1915 touring tail lamp bracket. It's missing the license plate holder/bracket.
The license plate holder bolts onto it via a threaded prong that goes through the hole and it is held in place with a castle nut.
The 1916 touring bracket is also a two-piece bracket except the license plate holder is riveted on.
Google the forum and you will see some examples.
- First Name: Don
- Last Name: Kirtley
- * REQUIRED* Type and Year of Model Ts owned: 13 and 16 touring, 18 and 20 coup, 20 tudor
- MTFCA Number: 23703
- MTFCI Number: 23153
- Board Member Since: 2009
Just cut the license plate bracket off the touring holder. That’s what I did. They are plentiful. Don
- Last Name: Giles
More details. I’ll use the one I have on the left minus the plate holder. I’m looking for another one to use on the right minus the plate holder. It’s for a Speedster.
- First Name: Joe
- Last Name: Bell
Bob, there is a couple around on the shelf will try to look tomorrow.
- First Name: Jack
- Last Name: Putnam
- MTFCA Number: 13833
- MTFCI Number: 13353
I have them. I reproduce the 15 bracket.
