1915 1916 Roadster / Coupelet Tail light bracket
Topic author - Posts: 35
- Last Name: G
I have a two piece tail light bracket which has the riveted attachment between the parts rather than the threaded piece and nut. I think a thread on the old forum indicated this could be for either 15 or 16, but some people have said this is only for a 1916. I am not an expert on these and don't recall what my car had.
Please see the photos and pm if interested.
- MTFCA Number: 121
- MTFCI Number: 16310
- Last Name: G
Re: 1915 1916 Roadster / Coupelet Tail light bracket
The riveted one wasn't used on the 1915's?
- First Name: Russ
- Last Name: Furstnow
- * REQUIRED* Type and Year of Model Ts owned: 1909 Touring, 1913 Touring, 1914 Runabout, 1915 Coupelet, 1916 Coupelet
- MTFCA Number: 28
- MTFCI Number: 10546
I want to point out that as an owner of a 1915 coupelet, this bracket cannot be used on a 1915 coupelet, as the opening lid for the trunk is at the rear of the trunk and not on the top of the trunk. This part is correct for a 1916 coupelet.
I hope this helps,
Russ Furstnow
I hope this helps,
Russ Furstnow
- Last Name: G
Hi Russ, Thank you very much!
- First Name: Dale
- Last Name: Peterson
- * REQUIRED* Type and Year of Model Ts owned: 1915 Touring, 1916 Roadster, 1925 Roadster PU, 1926 Canadian Fordor, 1927 Speedster
I would like the bracket if it is still available. PM sent.
- Last Name: G
Hi
The PM didn't come through, but I sent you an email.
