NRS parts for sale
Topic author - Posts: 987
- Last Name: Gould
NRS parts for sale
Recently sold a 1907 ModeL N Ford. Many extra parts for sale including new Brassworks radiator, Stipe cam, Jaehnert transmission frame, new timer. Much, much more at good prices. Price list and photos available.
Richard Gould
rgould1910@comcast.net
Richard Gould
- First Name: Rudy
- Last Name: Rathert
- * REQUIRED* Type and Year of Model Ts owned: 1909 1913 1914 1915 1926
Re: NRS parts for sale
Hi Richard I would like a list of parts and price. thank you Rudy
- First Name: rod
- Last Name: pellow
- MTFCA Number: 50951
Interested in getting a list. Please email me at Roddy@tcwreckersales.com or call 612-865-0049. Thanks
- First Name: Jim
- Last Name: Van Maanen
- * REQUIRED* Type and Year of Model Ts owned: 15 Touring, 19 roadster, 22 Coupe, 08 SR
- MTFCA Number: 373
- MTFCI Number: 184
Richard I am interested in the radiator. thanks
- Last Name: Gould
Steering column,$500
Rear axle tubes, $50
Frame cross members, $75
Four cylinders, $200
New Stipe cam with new timing gears, $600
Original crank and cam used, $150
Transmission frame new $2500
Used Gear case and brake drum $300
Water pump assembly $75
07 Holley carb, new $700
07 Kingston carb $1000
08 Holley carb $1000
Crankcase and front cover, $750
Timer, new $600
Two front hubs and plates, $250
Four pistons and rods $75
Four rods $50
Water tube and fittings $85
Ujoint $85
Intake manifold $150
Used timing gears $60
Pressure oiler $850
Side mount generator $750
Timer, new $600
Four rods $50
Ujoint $85
Pressure oiler $850
- Last Name: Gould
Timer, radiator, transmission frame, Stipe cam and new timing gears, all three carbs, original water tube, water pump and ujoint are spoken for.
- Last Name: Gould
Gear case and brake drum are spoken for
- Last Name: Gould
Pressure oiler is spoken for
- First Name: David
- Last Name: Dryden
I have sent you a PM
- First Name: David
- Last Name: Liepelt
- * REQUIRED* Type and Year of Model Ts owned: 06 N, 07 R, 08 SR, 13 Delivery, 15 Touring, 26 Speedster
- MTFCA Number: 20214
Has the crankshaft been magnafluxed? I am interested in crank and timing gears.
