WANTED FOR 1913 MODEL "T" TOURING
Paul B
First Name: Paul
Last Name: Bourgeois
* REQUIRED* Type and Year of Model Ts owned: 1913 TOURING
Post by Paul B » Tue Sep 08, 2020 5:09 pm
COMPLETE FRONT AXLE ASSEMBLY - SPRING, FRONT AXLE, ALL TIE RODS, LINKAGES, BRACKETS ETC.
ALSO: LEFT HEADLIGHT - BRASS RING, BUCKET, MOUNTING BRACKET & REFLECTOR
MTFCA Number: 14972
MTFCI Number: 15411
Re: WANTED FOR 1913 MODEL "T" TOURING
Post by RajoRacer » Tue Sep 08, 2020 6:55 pm
I might have what you're looking for in the front axle department - I believe that would be DB parts.
Paul B
First Name: Paul
Post by Paul B » Tue Sep 08, 2020 7:56 pm
HI STEVE,
THANKS FOR THE REPLY. WHAT IS "DB?"
MTFCA Number: 14972
MTFCI Number: 15411
Post by RajoRacer » Tue Sep 08, 2020 8:12 pm
Dodge Bros. - they supplied Ford with misc. chassis & engine parts in the "early" years.
Last Name: Gregush
MTFCA Number: 52564
Post by Mark Gregush » Tue Sep 08, 2020 11:19 pm
Re the head lights; people need to know who made the light you are looking for so it will match the right one. There were several companies that made lights for Ford in 1913. Some brands were made both sides the same no left or right. Maybe someone can chime in after you post the brand and say if there were left/rights for that brand or not. When you say need the left light, you need the drivers side?
1920 Dodge touring
ModelTWoods
First Name: Terry
Last Name: Woods
MTFCI Number: 20180
Post by ModelTWoods » Wed Sep 09, 2020 12:29 am
I was going to say the same thing as Mark. To get the correct matching parts, one must specify the maker of the light, ie. E&J, etc. I think in most cases the manufacturer of the headlights, cowl lights, tail light, and acetylene generator should match, at least they did on my 13. On all 13 and 14 models, the lights should be of the "black and brass" type, as opposed to the all brass used before 13.
Paul B
First Name: Paul
Post by Paul B » Wed Sep 09, 2020 1:13 am
THANKS TO ALL FOR THE INFO.
STEVE, I THINK YOU ARE RIGHT ON THE DODGE BROTHERS. I'D LIKE TO TALK WITH YOU ON THAT.
MARK, YOU ARE RIGHT, MY RIGHT HEADLIGHT IS PLAIN ON TOP & ONE I AM LOOKING AT TO BUY HAS BEAUTIFUL FORD SCRIPT ON IT!!!
TERRY; GOOD ADVICE. THE ONE I AM TRYING TO MATCH JUST SAYS "MODEL 2" ON IT.
REGARDS & THANKS
Post by Allan » Wed Sep 09, 2020 6:28 am
The left side of the car is always the left side. The driver's side can be either side, so it is more accurate to use left side , right side , than driver's side. That is it, unless you believe a left hand drive car becomes a right hand drive car if you are looking at it from the front!
Hope this helps.
