Re-Babbitting service , Model T main bearings
Gene_French
First Name: Gene
Last Name: French
MTFCA Number: 15614
Board Member Since: 2014
Post by Gene_French » Fri Sep 11, 2020 10:16 am
this is my "home rebuilders special" ... i re-babbitt and linebore the mainbearings in your COMPLETLY disassembled Model T motor block ... this is for standard configuration mainbearings , crankshafts and caps only ... the customer is responsible for determining the suitability of the motor block ,crankshaft , caps and bolts ... i recommend that the crankshaft be magna-flux checked , straightened and properly re-ground , and the block carefully inspected for defects ... i pour the bearings using a automotive grade high Tin babbitt , linebore mainbearings with laminated shin set inplace , machine cut side wells and oil grooves , face thrust and cut clearance radii ... price is $450 plus shipping or customer can drop off and pickup at my site in Nunn,Colorado 80648 ... always an optimist Gene French 970-581-2808
Gene_French
First Name: Gene
Last Name: French
MTFCA Number: 15614
Re: Re-Babbitting service , Model T main bearings
Post by Gene_French » Fri Sep 11, 2020 3:52 pm
Note: this is your DISASSEMBLED and CLEANED motor block ... always an optimist ...Gene French 970-581-2808
Gene_French
First Name: Gene
Last Name: French
MTFCA Number: 15614
Post by Gene_French » Sun Nov 08, 2020 11:52 am
to the top again , thanks MTFCA
Gene_French
First Name: Gene
Last Name: French
MTFCA Number: 15614
Post by Gene_French » Tue Dec 01, 2020 8:54 am
to the top again ...thanks MTFCA
Gene_French
First Name: Gene
Last Name: French
MTFCA Number: 15614
Post by Gene_French » Sat Dec 12, 2020 8:45 am
Gene_French
First Name: Gene
Last Name: French
MTFCA Number: 15614
Post by Gene_French » Tue Apr 20, 2021 10:31 am
1913Runabout
First Name: Brian
Last Name: Harlamoff
* REQUIRED* Type and Year of Model Ts owned: 1913 Runabout, 1922 speedster
Post by 1913Runabout » Tue Apr 20, 2021 12:28 pm
Hi Gene. Does a SCAT crankshaft of standard bearing size qualify as a stock crank? Thanks Brian
Gene_French
First Name: Gene
Last Name: French
MTFCA Number: 15614
Post by Gene_French » Tue Apr 20, 2021 2:43 pm
Brian:
we spoke earlier today , for everyones information ,what i mean by standard configuration is : not having to bore the bearing saddles and special caps to fit an oversize diameter crankshaft ... Model A or Chev. etc. ... the SCAT model T crankshaft is a standard configuration crankshaft and i will add that i have installed 11 and all have been excellent ... a job very well done ...my compliments to the manufacturer... always an optimist ...Gene French
Gene_French
First Name: Gene
Last Name: French
MTFCA Number: 15614
Post by Gene_French » Sat Apr 24, 2021 8:41 am
have done 2 SCAT crankshaft installations and 3 origional crankshaft re-pour so far this year ...thanks MTFCA
