Wanted: Original Brass Oil Cap For 1913 Ford Touring
Topic author - Posts: 339
- First Name: Gene
- Last Name: Emering
- * REQUIRED* Type and Year of Model Ts owned: 1913 Touring and 1924 Touring
- MTFCA Number: 49671
I would like to purchase an original 1913 brass oil cap in good condition.
Thank you,
Gene
Thank you,
Gene
Gene Emering
Newton, New Jersey
Newton, New Jersey
- MTFCA Number: 121
- MTFCI Number: 16310
Re: Wanted: Original Brass Oil Cap For 1913 Ford Touring
There are two styles of this cap. Learn what they are, and don't let someone sell you a reproduction! Good luck. Both styles say Made In USA under the Ford script.
- First Name: Mike
- Last Name: Bird
Here’s what you need to look for
http://www.mtfca.com/discus/messages/50 ... 1446574786
The early caps with the Made In USA don’t show up very often, so if you see one grab it when you can
- First Name: Adam
- Last Name: Doleshal
- MTFCA Number: 23809
- MTFCI Number: 1
FYI, I’ve found the “going rate” for a decent one is around $125-$150. I’ve seen them for more, but you can usually get one for that.
- First Name: Mike
- Last Name: Bird
This is the style that would be correct for late 1912-early 14.
- First Name: Gene
Thanks to everyone for all of the information.
I have a copy of the judging guidelines, so know what to look for.
Am I correct that none of the repros have the 'made In USA" stamped in them?
Gene
Gene
Gene Emering
Newton, New Jersey
Newton, New Jersey
- First Name: Gene
Gene Emering
Newton, New Jersey
Newton, New Jersey
- First Name: Mike
- Last Name: Bird
Correct on the repos not having Made in USA. I searched for mine for 6 years and gave up then 1 finally popped up on eBay. Can’t say if what you have there is original or not.
- First Name: Gene
Also, I have this steel one currently on the car.
1915 vintage?
I would trade or sell this towards one that is correct for ‘13.
What is it worth?
1915 vintage?
What is it worth?
Gene Emering
Newton, New Jersey
Newton, New Jersey
- First Name: Charlie
- Last Name: Gagel
- * REQUIRED* Type and Year of Model Ts owned: 12 Tourings(2),14 Tourings(2),15 Touring,22Touring,22 TT,21 Fire Truck,14 Chief Car
- MTFCA Number: 8377
- MTFCI Number: 22437
I believe that is for a 16
- First Name: Mike
- Last Name: Bird
Gene I sent you an email
- MTFCA Number: 121
The link that Gene posted is a very nice copy. I have seen those before. I fail to remember when Ford introduced the brass breather caps, but I believe it was in 1912. They don't say Made In USA.
- First Name: Bob
- Last Name: McDaniel
- MTFCA Number: 28428
My early 13. Engine was cast 12-24-12. No Made In USA. May have been a left over 1912 part.
- First Name: Gene
Found
Thank you MTFCA
Thank you MTFCA
Gene Emering
Newton, New Jersey
Newton, New Jersey
