Coil Tester - New
Topic author - Posts: 464
- First Name: Mike
- Last Name: Kossor
- MTFCI Number: 22706
Coil Tester - New
Brand New ECCT coil tester - This tool has earned the reputation as the New Standard for testing and adjusting Model T coils. The ECCT Actually measures how long it takes the coil to fire spark (Not coil current!). All coils can be precisely adjusted for equal firing time to minimize cylinder to cylinder ignition timing variation for optimal engine performance. Check out the website for more information: www.modeltecct.com
The New 3 in 1 coil adjusting tool simplifies point adjustment. All the tools you need to increase or decrease cushion spring tension or vibrator spring tension are all in 1 tool.
For more information, visit: http://shop.modeltetimer.com/3-in-1-Coi ... DJTOOL.htm
- First Name: Mario
- Last Name: Brossard
- MTFCA Number: 30981
- MTFCI Number: 30981
Re: Coil Tester - New
Hi Mike, I like your new 3 in 1 coil adjusting tool. Good idea. Keep your good work. Our T hobby need guy like you.
Super Mario Bross
1911 Touring
1914 Speedster
1911 Touring
1914 Speedster
- First Name: Mike
- Last Name: Kossor
Thanks for your comments Mario, appreciate the feedback.
- First Name: Mike
- Last Name: Kossor
Its coil maintenance and rebuilding season. Don't forget to set your points back to spec
- First Name: Mike
- Last Name: Kossor
The difference between an Engine that Runs and an Engine that Runs well is coils adjusted for equal and consistent firing Time.
- First Name: Mike
- Last Name: Kossor
New Year Resolution Suggestion: Learn how to Test and Adjust Model T coils.
(for equal and consistent firing Time using the ECCT)
- Last Name: Hjortnaes
- MTFCA Number: 28762
- MTFCI Number: 22402
It would be a great Xmas present. Order yours now.
- First Name: Neil
- Last Name: Martin
- * REQUIRED* Type and Year of Model Ts owned: 11 tourer 18 tourer 18 TT
Mikes question.
What's the simple difference between a HCCT and an ECCT ???
My thoughts !!! I am on the chopping block..
A HCCT is designed to adjust Model T coils to fire the cylinder combustion gasses at a pre-determened piston position either before or after TDC by a variable voltage and varying frequency alternating current (AC) power supply, say a Model T magneto.
The ECCT is a device that operates on a fixed direct current (DC) supply usually, say an internal electronic DC power pack.
Ideally used for adjusting model t type ignition coils for battery powered Model T Fords and speedsters that seem to use a higher primary current for a more advanced timing solutions.......N..
- First Name: Mike
- Last Name: Kossor
Neil, as you are aware, I explained the misnomer about using AC (HCCT) versus DC (ECCT) as the preferred stimulus for adjusting coils in detail back in this thread.
https://mtfca.com/phpBB3/viewtopic.php? ... es#p115785
Keep in mind the AC current does NOT reverse direction during each coil firing (same as a DC pulse). Yes, the polarity and current direction does change alternately with successive coil firings BUT that has no significant impact on the Time it takes the coil to fire spark regardless of current direction through the coil winding.
Adjusting coils using Current as an indirect approximation of firing Time is far better than adjusting coils by ear or on a buzzbox trster, no question. However, there is no better way of adjusting coils for equal and consistent firing Time than by actually Measuring firing Time using a fast pulse of electricty (regardless of pulse polarity) in my experience based on the data I recorded and would be happy to share. I would be very interested in reviewing your data if it supports a different conclusion.
- Last Name: Golden
- MTFCA Number: 14294
- MTFCI Number: 13562
The HCCT does not tell you the capacitor is bad, but it is always bad with original coils.
That probably was not a problem 60 years ago when the HCCT was new and top driving speeds were 20 MPH.
Coils seem to operate with no capacitor, but the points don't seem to last very long.
- First Name: Gene
- Last Name: Carrothers
- MTFCA Number: 22905
- MTFCI Number: 23068
This would certainly make someone a nice Christmas gift. I know I really enjoy mine!
1912 Torpedo Roadster
- First Name: Mike
- Last Name: Kossor
Coils with no capacitor (or bad capacitor with little to no value) are vulnerable to point arcing as the contacts break (open). The situation is similar to arc welding where the operator strikes the work with welding rod (i.e. closed contacts) then draws the rod away from the work slowly to draw the arc and begin welding. Similarly, the point contacts are subject to arcing as the contacts open with the transfer of metal from one contact and deposition onto the other while introducing carbonization and oxidization of the contacts which further degrade coil point operation. Unlike arc welding, however, the point contacts continue to separate widely until the arc eventually ceases. The consequence of this widening arc is a continuation of coil current with slowly decreasing value. When the arc finally ceases, the coil current reaches a value that is usually so low that the resulting collapse of the magnetic field is too weak to produce the high voltage necessary for electrons to jump the spark plug gap. In summary: No capacitor = no spark or very weak sparkCoils seem to operate with no capacitor, but the points don't seem to last very long.
The purpose of the capacitor is to continue the coil current flow through it instead of the points as the point contacts open. There are no significant voltage at the point contacts to produce an arc as the capacitor charges and the points begin physical separation. A very short time later (on the order of 0.000002 seconds) the capacitor becomes fully charged and can no longer pass current through it. Coil current rapidly decreases and the magnetic field collapses. This causes a voltage to build up across the coil points very rapidly BUT the contacts are now physically separated from one and another making it more difficult for electrons to jump the gap and produce an arc. The primary winding voltage builds rapidly to a high value (on the order of 250V to 300V) as the magnetic field collapses and in turn induces a very high voltage in the coil secondary winding through transformer action. How high the secondary voltage gets depends largely on the primary to secondary coil winding ratio; 1:80 for a typical Model T coil. The secondary voltage can be estimated by multiplying the primary voltage by the turns ratio, for example: 250V x 80 = 20,000 Volts which is more enough to jump a 0.025" spark plug gap under compression of 60 psi (~8,650V)
- First Name: Mike
- Last Name: Kossor
Still time for another New Year Resolution: Learn the art of coil testing and adjusting and keep your Model T running at peak performance year round.
WARNING!: Proficient knowledge and skills of Model T coil adjusting with the ECCT can be habbit forming. Incidences of increased popularity with requests for assistance from other club members; and in rare cases, complete strangers has been reported. People with a history of helping others enjoy the Model T hobby should give special consideration before acquiring an ECCT and learning the art of coil adjusting. Checking with your significant other to see if your time adjusting coils will be well tolerated is recommended. Happy New Year All!
- First Name: Chris
- Last Name: Lawrence
- * REQUIRED* Type and Year of Model Ts owned: 1926 fordor sedan,1927 fordor sedan. 1922 tourer, 1913 torpedo roadster pickup
- Board Member Since: 2014
Hi, i would l8ke to purchase a coil tester and program off you please, i have tried on your website, but it demands a state, as i am in new zealand. Any help would be greatly appreciated. Thank you. Chris Lawrence
- First Name: Mike
- Last Name: Kossor
Hi Chris, the website is not set up for international orders. Just send me an email ( mictel@comcast.net ) stating what you would like and shipping address you would like it sent and I will provide you a shipping quote with instructions for placing your order.
