Armature tester sold
Topic author - Posts: 1290
- First Name: Mike
- Last Name: Leonard
- * REQUIRED* Type and Year of Model Ts owned: 6
I have no idea about it make me an offer
- First Name: David
- Last Name: Houston
- * REQUIRED* Type and Year of Model Ts owned: 13,14,19,21,&etc
- MTFCA Number: 32227
- MTFCI Number: 23901
Re: Armature tester
Hello C-T L: Did you plug it in and /or test it ? Very simple just put an armature on it and see if it growls and bites the hacksaw blade.
Easy
POPS
Easy
POPS
- First Name: Chuck
- Last Name: Griffin
- * REQUIRED* Type and Year of Model Ts owned: 1925 Tudor Sedan
- MTFCA Number: 31570
Re: Armature tester
I will give ya 12 bucks.
- First Name: Henry
- Last Name: Lee
- MTFCA Number: 479
Re: Armature tester
Thats an original Blue Point! They work very well. Put a ground on it to prevent excitement!
- MTFCA Number: 14972
- MTFCI Number: 15411
Re: Armature tester
I've been using mine for over 20 years - where would you wire in a ground, Hank ?
- First Name: Henry
- Last Name: Lee
- MTFCA Number: 479
Re: Armature tester
On the base housing. Mine bit me twice so have it on a GFCI receptacle and three prongs.
- First Name: David
- Last Name: Dewey
- MTFCI Number: 19936
Re: Armature tester
Sounds like an insulation problem The "base" should be electrically issolated. Not that putting in a grounded wire cord isn't a bad idea though.
T'ake care,
David Dewey
David Dewey
- First Name: Henry
- Last Name: Lee
- MTFCA Number: 479
Re: Armature tester
David the test leads are hot with the light bulb socket. When it is a hot and humid day here in the south (down yonder), not a good Idea to test with old non OSHA approved equipment! LOL! No I do not have Parkinson's just shock therapy.
Re: Armature tester sold
Thanks Hank !
- First Name: David
- Last Name: Dewey
Yes, you do have to be careful with the test leads!
T'ake care,
David Dewey
David Dewey
